Engine flush needed??
Old Feb 21, 2009 | 01:24 PM
Benz_05_TSX's Avatar
Well, my car had been sitting at the shop for a little more than 6 months, is a engine flush needed?? i read on the web that its not the best thing to do. Then, what should I do since my car has been sitting for more than 6 months. Oil change for sure, but any other stuff as well?? Thanks
Noob
Old Feb 21, 2009 | 08:45 PM
npolite's Avatar
I would suggest that you just do an oil drain and fill (although not necessary). It is not necessarily to do a drain and fill of the transmission fluid. Do not ever have your transmission fluid flushed out with a machine as that will damage the transmission. And only use Honda ATF fluid.
Old Feb 23, 2009 | 03:03 AM
Wow, thanks for the reply. Ya i heard you shouldn't do a flush. What is an oil drain and fill?? Is that just draining out all the old oil and fill it back up with new oil? So basically like a normal oil change?
Old Feb 23, 2009 | 07:34 AM
npolite's Avatar
Correct
Old Feb 24, 2009 | 01:40 PM
PrecyseStylez's Avatar
Special-K
Honda ATF fluid sucks!
Old Feb 24, 2009 | 02:36 PM
curls's Avatar
Someone stole "My Garage"
And what would you suggest then? Please back up your suggestion with engineering facts and articles, just as Honda/Acura has done with their ATF over the years.
Old Feb 24, 2009 | 05:52 PM
npolite's Avatar
PrecyseStylez has no idea what he is talking about. There are only one or two other transmission fluids that will work on a Honda transmission and the debate is still out on that. If you want to play it safe you ONLY use Honda transmission fluid....unless you want to damage your transmission.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
BKSleeper
Oct 7, 2015 10:20 AM
Mike Bertram
Sep 10, 2015 09:27 AM
mtl_ilx
Sep 3, 2015 09:58 PM
