Eletrical Problem
Old Apr 5, 2009 | 11:12 AM
orbitup's Avatar
Eletrical Problem
04 TSX w/out nav
This is my wife's car and I don't know if it is related but I had the a/c comp. replaced right before this problem started.
Anyway... while driving or idling everything electrical will shut off and come back on again quickly. It usually happens so fast that the engine will just "hiccup". Sometimes afterward the CE and/or airbag light will stay on for a while. I checked the code and it's "P0685 ecm/pcm power relay control circuit/ open"
Last weekend I replaced the ignition switch with no luck. I was thinking if I can't find an answer here I will change the battery cables next. But I hate throwing parts at a problem so please, someone help me.
Thanks.
Old Apr 5, 2009 | 12:00 PM
orbitup's Avatar
I was just reading through the technical service bulletins a might have found it. Looks like it might be a bad neg batt cable or a bad ground someplace.
Old Apr 6, 2009 | 08:04 AM
litesout's Avatar
Oliver!!!
I'd check the negative terminal. If they took it off when they replaced the a/c compressor, it might have been damaged putting it back on. That's an odd presentation of the problem though. I just had a bad negative terminal on a buddy's Escort. It had charging problems and a slow start when it was cold, but never gave us any other problems. We carpool too when possible, so I spend a decent amount of time with the Escort (and he bought it off my sister, so I'm pretty familiar with it.) The problems you describe I had on my old Accord years ago, and it was an ignition switch. But you never know, it could be.
Old Apr 22, 2009 | 06:08 PM
orbitup's Avatar
I checked the voltage drop on the neg. battery cable like the TSB said and it was well out of range. $8 later and problem solved.
I would suggest that anyone with odd electrical should check theirs out.
Old May 20, 2009 | 06:25 PM
kwyatt318's Avatar
i'm having the same problem right now. i had acura change my battery a couple months back but i just started experiencing the problem like 2 weeks ago. the radio and MID came on and off a couple times today while i was driving. guess i'll take the car back to Acura and tell them to check the voltage. Thanks for the heads up!
Old Jun 3, 2009 | 01:08 AM
kwyatt318's Avatar
My car is still having that problem with the electric coming on and off really quickly. I took it to Acura twice and they cannot find the problem. I told them about the TSB and they checked the voltage but everything seemed to check out fine. I dont know what to do! Any suggestions??
Old Jun 3, 2009 | 06:59 AM
orbitup's Avatar
Try a new neg. batt. cable anyway. It's only a few bucks and really easy to change.
Old Jun 7, 2009 | 08:52 PM
kwyatt318's Avatar
okay i'll do that.
Old Jan 25, 2011 | 08:11 PM
ENTOURAGE-2005RL's Avatar
5th Gear
I am having this same issue on my 2005 RL. I have been told it might be a bad battery. DID THE NEW NEGATIVE BATTERY CABLE FIX THE PROBLEM?
Old Jan 25, 2011 | 09:40 PM
main70072's Avatar
The OP noted that it solved his problem.
Old Jan 25, 2011 | 10:34 PM
orbitup's Avatar
It did fix the problem. And for less than $12! What do you have to lose?
It's been almost 2 years and it hasn't happened since.
Just noticed I misspelled 'electrical' in the title.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
