Drivers side radiator fan motor
the easiest way is to drain the radiator because you have to take off the upper hose from the radiator.
there is one screw/bolt holding the fan assy in place below. Just loosen it.
remove both top screws and the radiator resorvoir
To make the job easier, remove that little top radiator bracket and the plastic air intake shroud. disconnect the fan connector. As you're pulling the assembly up there is a wire harness underneath that just detaches.
Hope that works out
Hope that works out
Hope that works out
Hope that works out
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
