driver fog connection freakin out
Old Dec 7, 2006 | 01:47 AM
San-AnT's Avatar
The Power of a Grill
anybody ever have a problem with the fog lights? I had my front bumper replaced and ever since, the driver side fog will go out for a week or so. then suddenly work again. it's not the bulb and i've checked the connections. I even had to replace the housing because the other fog glass got shattered on a rock, so both replaced. then last week the light went out again. when it worked, it would hesitate for a second then turn on (just after the other would turn on). I cant figure it out.
maybe coincidence, but the light goes out around the time when i replace my backup light. (had led, it was blown, so i replaced with OEM). maybe crossed wires somewhere?
Old Dec 7, 2006 | 05:33 AM
dwest1023's Avatar
Sound like you have a bad ground somewhere.
Old Dec 7, 2006 | 10:56 AM
San-AnT's Avatar
but why would one fog stay on and the other not? they both use one ground.
Old Dec 7, 2006 | 11:27 AM
dwest1023's Avatar
They may both use ground, but at the point the ground comes together down to the one fog could be the problem. Try running a sperate ground wire from the one bad lamp and see if the problem stops. This way you will know instead of guess work.
Old Dec 7, 2006 | 11:29 AM
San-AnT's Avatar
roger that. thanks. i think the wires may have been pulled too hard when replacing the bumper, and that may have resulted in a loose ground...
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 17, 2015 09:01 PM
AZuser
Sep 17, 2015 10:15 AM
