The Dreaded P0341 Code - Repair Shop Recommendation (Austin, TX)
I recently got the P0341 code as well and the dealership informed I would need the timing chain and tensioner replaced. Can anyone recommend me to a reputable local repair shop in Austin, TX? I would like to avoid the high dealership costs if possible especially since I'm on a tight budget.
Thank you in advance for your response and assistance!!!
babyd927 (11-30-2011)
Are you sure that is the problem? You may want to go get a second opinion before dropping a bunch of money on what may not be the problem. It could be the camshaft position sensor or wiring connections...
babyd927 (12-01-2011)
in the 24th and a half...
Dreaded, huh? "P0341 - Camshaft Position (CMP) Sensor and Crankshaft Position (CKP) Sensor Incorrect Phase Detected"
OK:
1) Has the dealership performed a diagnosis on this vehicle yet? I ask, because replacing the chain and/or tensioner is NOT the first step on a P0341 code. To determine this is necessary means at least opening the tensioner inspection plate on the timing cover, at a minimum, and even then it's an educated guess.
2) The real check on cam stretch/timing involves removal of the cylinder head cover...was this done?
3) The first 9 troubleshooting steps involve checking it's not a transient issue, then it's check the VTC oil control solenoid valve (step 10), them they get to the cam chain timing (step 11) and possible stretch (step 12).
4) Problems with the VTC oil control solonoid valve have cropped up on here with some frequency. The most common issue seems to be either a clogged filter screen on the valve or simply low oil level.
If the stealership jumped immediately to replacing the chain/tensioner, run away! If they did a diagnostic, ask for a copy of their data and checks.
OK:
OK:
OK:
For example, if you changed the oil every 5000 miles, did the oil level on the dipstick change between oil changes? Did you need to add oil between oil changes?
Thanks!!
OK:
OK:
Yeah, to me it's "dreaded" based on comments provided by other drivers in this forum. It's not a cheap repair at the dealership since they quoted me ~$1900. Go figure...the dealership's margins are ridiculous.
I went in for an oil change and had the dealership read the code associated to the check emissions light (which I already knew). They informed me my timing chain was stretched and I needed to complete the repairs right away before I caused additional damage to the engine. Unfortunately, I did not ask for a copy of their data/checklist but instead was provided a list of repairs needed.
In terms of the other troubleshooting steps you outlined...I'm not certain if it was completed by the dealership...I may need to get a 2nd opinion but need a recommendation to a repair shop in Austin. I've had nothing but bad experience going to shops based on yelp reviews and etc...
In the last 3 oil changes I have noticed that I was consuming more oil than prior oil change intervals. I went to the dealership in Houston and completed a compression test and all cylinders checked out within Acura's spec. At that time I was still under extended warranty so the dealership and I called them to determine if they would cover a breakdown of the engine to determine the issue. No go and rejected...the extended warranty broker informed us my oil consumption was normal for an Acura. I was roughly burning a quart of oil every 3,000 miles and needed to add oil in between oil changes. Needless to say my warranty expired in Sept and now I'm in need of repairs...
Suggest the following page:
http://www.texas.aaa.com/en-tx/buy-m...s/aarhome.aspx
Enter your car and zipcode data and check out the results. At least they meet some standards. Consumption is high.
The VTC oil control solonoid is located under the top cover, the one just beyond the oil fill, to the passenger side. The screens are integral, and no a maintanence item.
babyd927....Check out the thread "Disappearing oil" below...The amont of oil you are using is very similar to my experience... Replacing the PCV valve has pretty much fixed the problem. My TSX was starting to use about 1 quart every 2,500 miles. With the new PCV valve it has used less than 1/4 quart in th 3,000 miles I've driven since the valve was replaced.
http://estore.honda.com/acura/parts/...your-acura.asp
The select your year...model...version...engine...VTC oil control valve...and then look through the parts for the VTC oil control (#007 on a 2006 Navi 6-mt). You can zoom the picture, and the part with the o-ring on the end is the filter portion you could clean.
Miamicarfan (12-03-2011)
Go here...
