Doors lock automatically when ignition on
Old Jan 27, 2010 | 09:58 AM
440Sixpack's Avatar
3rd Gear
Hello,
I've managed to lock myself out of my car after changing my battery, luckily I had the extra key.
I start my car, get out of the car and shut the door and all the doors lock automatically, why is this happening as it didn't before?
Is there a way to reset this so the doors do not lock. This is a factory stock car with no mods.
Old Jan 27, 2010 | 10:10 AM
LuvMyTSX's Avatar
What model year? Navi or no?
Old Jan 27, 2010 | 10:45 AM
darowa's Avatar
There is a "feature" that if the doors are unlocked by the key fob and no door is opened - the doors lock themselves. This does not seem to be the case here but it is one way the car will lock the doors automatically
Old Jan 27, 2010 | 10:55 AM
LuvMyTSX's Avatar
Yeah, that's what I thought it was going to be before I read the description of the problem, but obviously that's not it. Hmm.
Old Jan 27, 2010 | 11:16 AM
darowa's Avatar
Perhaps the disconnecting of the (old) battery and reconnecting the (new) battery has initiated that "auto-lock" sequence?
Old Jan 27, 2010 | 11:51 AM
440Sixpack's Avatar
3rd Gear
Its a 2004 Acura TSX. No navi.
Old Jan 27, 2010 | 01:19 PM
Santa Rosa Steve's Avatar
2006 DGP Sold 10/24/2012
Did it happen more than once?
These first-gen TSXs didn't have an autolock feature other than the relock if you neglected to open the doors after you used the remote.
Old Jan 27, 2010 | 01:29 PM
440Sixpack's Avatar
3rd Gear
Yes, it happens consistently.
Old Jan 28, 2010 | 02:25 PM
Nogard13's Avatar
How much time passes from the time you close the door to the time it locks?
Does it lock when you turn the car on if the door is closed?
Does it lock after you turn the car on, with the door closed, when you put it in gear?
This sounds pretty crazy, but maybe you stumbled on an Easter Egg on auto-locking the doors. Tell us more about the "feature" so we can make a better guess at the problem.
Old Jan 30, 2010 | 12:19 AM
llwtsx's Avatar
Are you the original owner of the car?
If you're not, perhaps a previous owner added one
of the KP Technologies auto lock / unlocking modules
and it was reset/re-enabled because of the battery
change:
http://www.kptechnologies.com/produc...cura&model=TSX
Old Feb 8, 2011 | 01:51 PM
joebinfamouz's Avatar
this same exact thing happend to me, since this past friday! i had no spare key and it locks as soon as the door is closed! only while the engine is running though. I can hear it click over to try and lock the door and it does this twice then after the door automatically locks by itself. Now the other doors wont open with the remote either! Has anyone else ever had this problem?!
2004 Acura TSX
Old Aug 3, 2012 | 07:51 PM
screech2001ja's Avatar
2004 Acura TSX
did you find a fix for this problem. i seem to be having the same now. on an 05 tsx
Old Sep 5, 2012 | 09:27 PM
BrklynVez's Avatar
im having the same problem as well but it happened in a situation where i was trying to impress a girl i was going on a date with and went to the store real quick to come back to my car being locked while the key was in the ignition and worse in the middle of the street double parked -_-
Old Dec 3, 2013 | 08:14 PM
Vlad1608's Avatar
5th Gear
I have the same problem, who know the answer of this problem?
Old Dec 6, 2013 | 01:07 PM
Crxej1's Avatar
same problem here, just got a tsx 3 days ago and had the same problem;(
had to pay tow truck $50 to open my door
2007 tsx w/navi
Old Dec 28, 2013 | 10:16 AM
dbotteicher's Avatar
Has anyone resolved this problem i have the exact same problem on an 01 tl
Old Dec 29, 2013 | 03:45 AM
mau108's Avatar
usually means a bad door actuator. Trying unplugging one door actuator (probably driver side) and see if it auto locks as you shut the door. Had the same problem on my old 2001 Honda Prelude and it was the door actuator going bad that was causing the autolock.
Old Mar 7, 2014 | 02:55 PM
Not trying to bump an old thread but i figured out the problem I was having. So, i was going through everything on the door. Checking all the switches for continuity and all connections. i finally got frustrated and when i was putting it back together i noticed that the plug that goes from my lock knob to the actuator wasn't clicking in place. after further investigation i noticed two seals in the plug. so i pulled one out and it clicked in and works flawlessly now. now i know that isn't going to be everyones problem but you can go from there and make sure that the knob switch is working by checking continuity and also the cylinder lock switch. hopefully this helps someone i really could've used this six months ago when the problem first arose.
mlody
Dec 4, 2019 02:11 PM
BIGxRED
Oct 19, 2015 10:47 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Juandiablo
Sep 27, 2015 10:32 AM
