Door Lock Problem (Sticking)
Old 08-13-2007 | 09:13 AM
  #81
Nighthawk04's Avatar
So as I was going through the how-to, I decided to call my three local Acura dealers for installation quotes just to see if I would be wasting my time *trying* to do this myself. $96 (total cost considering that I already have the part) at Woodfield Acura in Schaumburg, IL! I'd rather it be them who screw up my door.
Old 08-13-2007 | 12:04 PM
  #82
afax226's Avatar
I am glad that I found this post. I noticed last Friday that my passenger door lock was sticking too. If I lock and unlock consecutively back-to-back, it wouldn't work. I can either lock or unlock at a time. If I wait for 5-10 secs between locking and unlocking, it would be working fine. It is not a big problem right now because not often that I need to lock and unlock back-to-back. I am just afraid that this will get worse over time.
I just passed the warranty period by 6000km. Honda Canada wants me to pay $99 for diagnose and hopefully, they will replace it under good will. What should I do?
Old 08-13-2007 | 01:25 PM
  #83
jhc's Avatar
jhc
I'll be surprised if you guys get outta the dealer's garage for under $100... but good luck. Maybe you're better friends with the service manager than I am...
Old 08-14-2007 | 04:50 PM
  #84
$98.40.
Old 08-16-2007 | 03:42 AM
  #85
NopiGirl's Avatar
Well at least I know an Acura dealership should be able to do it for about $100 - I'm ok paying that then spending the time and frustration of doing it myself. I'll have to call tomorrow and see what they quote for time. I have to say, after owning an Acura for years, I'm disappointed that something like this would be such an issue so soon.
Old 08-22-2007 | 08:13 PM
  #86
endswithaW's Avatar
nub
had the same problem. 2004 TSX. had it replaced under warranty. acura dealership knew what it was because they had a service bulletin for it.
Old 08-22-2007 | 08:45 PM
  #87
palidanx's Avatar
honk not beep
On my 2004 tsx, my driver's side lock began going up and down real slow so they replaced it at 49,600 miles. Luck I got it in before my 50k. Bad enough that the passenger's side lock died at 40k.
Old 08-24-2007 | 07:39 PM
  #88
gbaker's Avatar
I just had the driver's door actuator replaced on my 2004 at 70k. Easy fix, covered under my Acura extended warranty. Funny thing was, the passenger side started moving slowly, then the driver's side actuator suddenly stopped working altogether. Now both are fine.
Old 09-19-2007 | 02:53 PM
  #89
neo661's Avatar
guide
Thanks Nighthawk! This is the answer to my prayers! The STEALER wanted 188 to fix! i went on oemparts.com and i found it for $17.54 plus S&H.
I have a friend that works in window replacing. He might be able to help me out quite a bit. Thanks again!
-neo661
Old 09-19-2007 | 02:57 PM
  #90
dom's Avatar
dom
Originally Posted by djpinoy
Hi everyone,
Just did this today on my '04 TSX, following BW61885's original directions. Took lots of pics of the whole process plus some pages from the actual service manual.
http://www.facebook.com/album.php?ai...5&id=502851915
The Acurazine forums have always been a great source of help for my car. I'm hoping that this helps someone out there.
Cheers,
djpinoy
Hopefully I can get this done before winter.
Old 10-03-2007 | 10:37 AM
  #91
TonySX's Avatar
My driver's side actuator just failed. '05 with 30K miles.
Old 10-03-2007 | 11:38 AM
  #92
afax226's Avatar
Honda Canada covered the repair cost 100% for this one. I just hope that the other 3 won't give me any problem any time soon. I am not holding my breath on this one though.
Old 10-03-2007 | 12:57 PM
  #93
vwong's Avatar
n00b
Wow...I didn't know the door lock is another problem. Mine failed yesterday. I'm going to pick up the actuator from the dealer later today and fix the problem.
Old 10-07-2007 | 05:24 PM
  #94
amadeus303's Avatar
TSX Sold! Hello STi!
Add me to the list as of this afternoon... Front driver's side on an '05 @ 39k miles. So friggin' annoying --- the fob is useless b/c you have to manually open the door with the key. I'll give the dealer a call tomorrow since I'm still under warranty...
Old 10-08-2007 | 10:03 PM
  #95
godfather2's Avatar
Time to Climb
My driver side actuator went out for a second time! Out of warranty now, is there a recall?
Old 10-12-2007 | 11:16 PM
  #96
skarun17's Avatar
9th Gear
looks like the actuator on the f passenger door went out today on my '05 tsx at 34k. its covered under warranty (also have extended warranty). i got the car in new york and am currently residing north of princeton, NJ. would i be able to take the car to any closeby dealer? any inputs on "relatively" reasonable acura dealers in the neighborhood???
Thanks!!
Old 10-13-2007 | 01:05 AM
  #97
lilasiian8's Avatar
I notice my front passenger has resistance when unlocking but it hasn't gone out yet.
Old 10-13-2007 | 02:12 PM
  #98
hondatypes's Avatar
add me to the list..04 tsx
Old 10-19-2007 | 03:53 PM
  #99
gta_g20t's Avatar
7th Gear
2005 tsx, drivers door actuator dead @55,000km. I'll be doin the install tomorrow afternoon. part was $46cad@ajax acura
Old 10-19-2007 | 06:20 PM
  #100
Highrev1's Avatar
After replacing mine, I opened up the "broken" one to see what could go wrong. The switch or motor are the only two possible items. The gears and whatnot appear to be working perfectly.
Old 10-22-2007 | 03:11 PM
  #101
neo661's Avatar
Thumbs up something awesome
So, i have been having the same problem everyone else has been having with this stupid actuator going out. I have been living with it for about a month. It took some time for me to get used to the idea of putting my key in EVERY TIME to lock and unlock the car. I did, however, discover something I should have known when I bought the car....if you turn the key to lock the car, hold the key turned in place inside of the the keyhole and have the windows down, the windows go up. I feel stupid just discovering this after 3 years of having my car....i know, huge embarassment to my fellow TSX'rs. ANYWAY!...that was a side note. Here's what I want to say to you guys....
go to oemacuraparts.com and ask for the part#72155-SDA-A01. They had it in stock when I ordered it and the customer service was i had it shipped overnight but they sent it to the wrong address, i called them back and they refunded me the shipping costs.... part ended up only costing 24 bucks with tax! im gna get it replaced this weekend by a friend that replaces windows... hope everything goes well...
Old 10-23-2007 | 01:56 PM
  #102
gta_g20t's Avatar
7th Gear
did mine this weekend in 3 hours including the trip inbetween to the store to buy the correct screwdriver to remove the latch assembly from the door.
make sure u unbolt the 10mm bolt on the front door to remove the window support bar you will see it with the big washer
Old 10-23-2007 | 02:45 PM
  #103
neo661's Avatar
Cool dude!
dude! could you tell me what else to look out for while I am doing this? I dont want to get stuck....thanks bro!
Old 10-24-2007 | 05:10 PM
  #104
dmbfan36_23's Avatar
Funny story, I took my car in for an oil change this morning and everything worked when I got there. I got my keys back after they were done, went out to my car and it wouldn't unlock. The service manager already had a rod up his ass over my car becuase I brought my own synthetic oil in for the change. I go back in and tell him it's not unlocking and he has this "you're full of shit" look on his face.... he comes out, tries the thing 30 times and sees it's not working. The lights flash and car beeps with the remote, the trunk opens... the car unlocks manually. So he says "well we only did an oil change... doesn't make sense"... and he looks at me expecting me to say "yeah I broke it".... I said "I'm not accusing you of anything, it's weird... I admit it.. but it worked when I got here... ask your service guy". He tracks down the service guy who says it did in fact work when I got here, so now this guy feels like an ass. He says "maybe it's the battery, maybe the signal isn't strong enough". I think "are you a moron? the car flashes and beeps, it's getting the signal just fine....", but I bite my tongue. They swap the battery - still no go. He then says "maybe it's the actuator... maybe it's failed by coincidence while you're here".....
So after all that they had one in stock, replaced it and viola, it works.
2005 TSX, just shy of 39K, covered under warranty.
Old 10-25-2007 | 03:16 PM
  #105
neo661's Avatar
Thumbs up morons
morons. i hate the STEALER!ship now. i dont go anymore until i ABSOLUTLEY need them.
anyway, sorry to hear about your story brotha'. hope everything works well with your new actuator.
Old 10-30-2007 | 04:05 PM
  #106
gfd1182's Avatar
my friggin passenger side actuator went, i had my driver one changed about 9 months ago! these actuators suck! thanx for the part number oemacuraparts has it for cheap compared to the stealership!
now i have to see how much my local mechanic is going to charge? does anyone know any mechanics that could change it in new jersey,
i live by jersey city but willing to travel in moderation.
Old 10-31-2007 | 08:55 AM
  #107
gta_g20t's Avatar
7th Gear
only problem I honestly ran into was getting the three phillips screws out of the drivers door that hold the actual lock in the door. "When you open the door on the b pillar you will see the latch, now on the door you will see the lock, you need to remove the three screws. I had stripped all three because of not having the right sized driver, so luckily for me after going to the hardware store and getting a driver set that did not work my neighbour had an extractor which he helped me use and I still reused to screws for assembly afterwards. It was not a great experience but was very satisfying after having the door working after theh fact
Old 11-02-2007 | 05:21 PM
  #108
neo661's Avatar
Thumbs up
awesome bro. thats the same problem i ran into. took about 3 hours. i didnt realize you had to take out the whole freakin' lock module. the screws were screwed in there pretty tight. but, like you said its all worth it when its done.
Old 11-03-2007 | 04:06 PM
  #109
hondatypes's Avatar
took me 3 hrs ++++........!!!!!!!!!!! : (
Old 11-07-2007 | 10:46 AM
  #110
DesertFox's Avatar
Nissan Titan in
well i found this thread using search, i have the same problem on my 99 honda accord, im probably gonna buy the parts and attempt this later on this week(if i can get my car in my garage, gotta convince my mom to let her 82 vette sit in the driveway while i do it) do you think the process will be pretty much the same for me?
Old 11-12-2007 | 01:37 PM
  #111
peter_bigblock's Avatar
C'mon, man! Row yer own.
My driver's-side actuator must have crapped out a couple days ago, I have the same symptoms on my '04. It had been going up and down more and more slowly for a while, probably a year (and used to be under warranty) but I didn't think much about it. I just ordered a replacement actuator from Delray, came to about $28 w. shipping.
I wouldn't have taken it into the dealership even under warranty -- don't trust those fools, plus I'm going to do a speaker install at some point so I'll throw the actuator in when I do that. Doesn't sound hard, I have the Helms manual and the great instructions from Azine!
Funny, I was just reading today that the TSX is, once again, one of Consumer Reports' most-reliable luxury cars. A lock actuator isn't a big deal, but it sounds like it's a problem that spans a few model years and the replacement part is just as crappy as the original -- hasn't been solved by Honda.
Old 11-12-2007 | 04:58 PM
  #112
99NCAA's Avatar
This seems like a major issue
Has any one contacted Acura? I'm thinking they should be covering all these failures with a recall. I am calling them tomorrow. I am a three time Acura buyer, and fully expect them to take care of my problem. It seems like an epidemic of bad actuators....
Old 11-12-2007 | 05:27 PM
  #113
Simba91102's Avatar
Old Guy
Sounds like this is still an issue. I say still because I had the same thing happen (faulty actuator) to a rear door of a 92 Accord (like 13 years ago). Ironically, the Acura dealer was allot closer than the Honda dealer, so they ended up fixing it. I was around 2K miles past warranty if memory serves (remember it's 3 yr., 36K for the Honda) and I had to pay for it. I wrote a letter to Honda expressing my disappointment in the (in my opinion) pre-mature part failure (and the timing) and they not only responded but reimbursed me for the repair. Sound like Honda still has the same supplier.
Old 11-12-2007 | 05:57 PM
  #114
hooraysimpsons's Avatar
My driver lock actuator went out on me a while ago as well. I can tell that my passenger side one is getting ready to fail.... Probably will as soon as the warranty is over... Oh well, I've opened up the door before so it shouldn't be a big deal.
Old 11-21-2007 | 08:04 AM
  #115
99NCAA's Avatar
I ended up bring my car to the dealer. They fixed it for free, with little resistance. I explained to them that I saw a bunch of people on the Acura forum with the same problem, and since it seemed that there are a ton of lock problems out there, it should be covered regardless of how many miles are on the car.
Now I can't wait for the next lock to go....probably within the next year I guess.
Thanks for everyone's input on this.
Old 11-25-2007 | 08:52 AM
  #116
jpesce01's Avatar
happened to my 04 TSX twice and only a few months apart under 20k miles...luckily still under warranty
Old 01-10-2008 | 01:00 PM
  #117
Tsx536's Avatar
Rep'n Taxbrain.com
Hi everyone,
Cheers,
djpinoy
Just wanted to bump for a great writeup. I'm most likely going to be doing this install soon. People seem to mention 3 screws that are hard to get out. Does anyone know if I need an impact screwdriver?
Old 01-16-2008 | 05:00 PM
  #118
Tsx536's Avatar
Rep'n Taxbrain.com
Bump
Old 01-16-2008 | 11:09 PM
  #119
tsx4lyfe's Avatar
oo jeez i have an 08 does anyone have an 08? hopefully this wont happen to mine
anyway this is random but im thinkin of gettin giovannis maybe in the spring.. could i put them on or is there specific rims for tsx?
Old 01-17-2008 | 01:17 PM
  #120
Tsx536's Avatar
Rep'n Taxbrain.com
Ended up getting the part from www.oemacuraparts.com
This is an Acura dealership in Phoenix, Arizona.
TSX Front Left Door actuator: Part# 72155-SDA-A01
They had the cheapest price. Order Total: $24.57 shipped to Cali.
2jiggy4u (06-30-2012)
Quick Reply: Door Lock Problem (Sticking)
