Does this sound like a problem?
Old Jul 29, 2005 | 12:17 PM
sccmoore's Avatar
When driving, right before I come to a complete stop, there's a creaking sound coming from the rear of the car. Can't hear it any other time. TSX only has about 9,500 miles on it. Should I get this looked at?
Old Jul 29, 2005 | 12:20 PM
RMATIC09's Avatar
Old Jul 29, 2005 | 12:21 PM
curls's Avatar
Someone stole "My Garage"
I think someone else has had this similar problem before, or maybe it was while cornering, but they said that after numerous visits to the dealer, it was found to be a spot-weld connecting the rear bracing (under the parcel shelf) to the unibody.
Might be completely off on that one, though.
Do you hear the same noise when going slowly over speed bumps (without braking at the same time, and then with braking at the same time) ? If so, it might be a prematurely worn bushing, or a cracked spring (happened on my 1991 Teg once)
~Eric
Old Jul 29, 2005 | 12:43 PM
iamhomin's Avatar
04 remembrance
So the sound is only audible right before you come to a stop? Does the sound appear when you're on uneven surfaces?
Old Jul 29, 2005 | 12:51 PM
sccmoore's Avatar
I can hear it the most when I come to a stop. I'll have to pay closer attention when I'm driving to see if I hear it any other time.
Old Jul 30, 2005 | 12:40 AM
Alin10123's Avatar
Probably something caked onto the brakes if it only happens when you drive etc...
If you've never heard it with anything else...
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
marcelft
Jul 10, 2018 06:17 PM
Azonics
Sep 22, 2015 05:28 PM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
