DIY - Steering Wheel Rattle - PLZ HELP
RooDHawG
I have the steering wheel rattle on my new 2006 w/ 200 miles on it and read here that it is most likely the airbag wire/harness that is loose and causing the noise. I have also read about how dealers are in such a hurry to correct this problem that they end up scratching and scuffing up the interior in the process. I am guessing I might be able to open up the steering wheel and correct this problem myself thus avoiding any dealer contact who doesn't care about my new precious. My worries are accidentally deploying the airbag when attempting to access the harness...so has anyone attempted to tackle this little nuisance themselves and completed it successfully? If so, please enlighten me.
Why not disconnect the battery, then there are not worries.
RooDHawG
RooDHawG
Originally Posted by Acurasrule
Is the Steering wheel rattle something that has a TSB issued for it?? I have an 06 AT and I am noticing a rattle/vibration from the steering wheel as well.
That would be an option though I would rather not do that as I have heard I loose all of my custom voice entries and stuff...might be my only options though to be entirely safe. Also need ing to know how to get the steering wheel cover off and not break anything.
Oh, you know that an airbag has the potential to go off once you remove it? And if you do disconnect any airbag device with the battery plugged in, it will get logged into the computer and you may very well pop a SRS warning light which will require you to visit the dealer and I bet they will have a few questions.
Just a little FYI for anyone thinking about DIY.
RooDHawG
Originally Posted by moda_way
Just an observation, but how do you know you won't wreck your interior any worse than an Acura mechanic? At the very least, if they do mess up your stuff, you don't leave the lot with the car. You bring the Service Mgr out an politely explain that his service guys are a bunch of fkin idiots and you want everything messed up fixed.
I would worry about losing your warranty. I believe (correct me if I'm wrong) if you handle the car yourself you loose your warranty. You need to take it to your authorized Acura service department.
I have a similar problem with my steering, I'm not sure if it the same problem but when I turn the steering wheel, either left or right it makes a squeaking noise as if something is rubbing inside. Also as I'm driving I hear a noise as if there is a small rock or object, lose inside jumping around. It’s really subtle but is there.
I took it to the dealer two times now, and the noise is still there, I have an appointment for this weekend, to see if they can find the problem once more.
The first time I took it they thought it was the power steering system; they kept my car for 3 days and replaced the whole system. And the noise remained.
The second time I took it, they kept it for another 3 days and they replaced a band in the steering wheel. They told me that if the problem continues that they will replace the steering wheel.
I will see what happens this weekend when I take it back, hopefully it fixes the problem.
I recommend that you try going to a small dealer where they do not get many cars, and try not to rush them, If they need to keep the car for a couple of days let them, but make sure you get a loner.
^^Not necessarily true at all. It is more or less around specific areas. For instance, if I change my own oil and can prove atleast on their schedule, then that won't void the warranty. However, if I reflash the ECU, then just about everything can be called into question. So it depends.
Thank for clearing that up for me.
rockyboy
08-04-2024 10:35 AM
