Cracked TSX navi screen
Old Sep 25, 2012 | 06:15 PM
zatzat's Avatar
Hi,
I have a 2007 Acura TSX. Unfortunately the navigation lcd screen cracked recently. It's very expensive to replace it with a new one. But I managed to find an aftermarket lcd screen which is more affordable. I now need to figure out how to replace my cracked screen with this other one. The person I am buying the lcd screen from said that if I can remove the stereo/navi unit myself and ship it to them, they could replace the lcd screen for me.
I found a few websites detailing how to remove the stereo/navi unit (but any more pointers will much appreciated, since I am a complete novice at this). What I want to know is, once I remove the stereo/navi unit and ship it to this person, will I be able to operate the car still? I understand that several functions like the A/C will not be accessible, but will the car run OK otherwise for short trips?
Thanks!
Old Sep 26, 2012 | 05:55 PM
RA032025's Avatar
in the 24th and a half...
One of the easy to see problems is that the circuit board that controls the LCD and it's function mounts on the back of the LCD display. If you have the correct unit, you're OK...if it's just an aftermarket unit that's the same size, you're gonna have a real lash-up behind the panel.
I don't think it'll work. Your best bet is getting the model off the unit (probably an Alpine unit) or buying a model from the junk yard.
Old Sep 26, 2012 | 07:53 PM
zatzat's Avatar
Thanks - I already managed to get the right lcd screen, so that isn't the issue. The question is whether I can operate the car after I remove the stereo/navi system and ship it to the person to have the lcd screen installed, i.e. will the car run?
Old Sep 26, 2012 | 08:26 PM
RA032025's Avatar
zatzat, why so complex? After you remove the unit, flip it over, remove the audio mounting screws and remove the audio unit, remove the cover over the board, unscrew the board, unscrew the 5 screws that mount display unit (that's the LCD and if the unit you have has screw holes to mount the board on the back and about 5 screw holes around the edge, it slots right in there), remove the display unit. Reverse to install.
Old May 26, 2014 | 10:01 AM
jaydog78's Avatar
3rd Gear
Originally Posted by zatzat
Hi,
Thanks!
What's the link to the website detailing how to remove the stereo nav unit?
ivegotthenav
Sep 11, 2015 07:51 PM
Gianni Formica
Sep 7, 2015 08:28 PM
yahelou
Sep 6, 2015 09:12 PM
Rexorg
3G MDX (2014-2020)
Sep 3, 2015 12:40 PM
SUPRMN84
Sep 2, 2015 11:50 PM
