Clicking noise from left front wheel.
Old Nov 19, 2012 | 09:49 PM
Hanneman's Avatar
7th Gear
I recently did a brake job on my 2008 TSX, and now there is an intermittent clicking/ticking noise from the front driver's side wheel. The rear pads and rotors were replaced. The front pads were ~7 mm thick, so the original pads, shims, and retainers were cleaned, regreased per the Helm's manual, and reinstalled. The front calipers and rotors were not removed.
The noise is usually only audible with the window down or in close quarters, like a crowded parking lot. The clicking noise depends on speed - approximately 2-3 times per second at 30 mph. Also, the clicking noise will stop when the brakes are applied. The problem is intermittent, and will sometimes start and stop randomly. I haven't noticed any difference in the sound while turning.
Unfortunately, I lost the lug key - Murphy's demon strikes again - so I won't be able to remove the wheel until I get the replacement.
Any assistance is greatly appreciated.
Old Nov 20, 2012 | 03:42 PM
burijon's Avatar
Remove the caliper bolts and regrease them. Mine did the same thing(still do somewhat) until I put some more grease on them. This helps them float better too.
Old Nov 20, 2012 | 11:34 PM
npolite's Avatar
Once this happened to a friend of mine when he didn't tighten the bolts hard enough that hold the caliper to the to the hub.
Old Dec 5, 2012 | 06:04 AM
Hanneman's Avatar
7th Gear
I finally got around to looking into the problem, and the culprit was one of the pad retaining clips. The lower retainer refused to sit flush in the caliper bracket causing one of the inner tabs to lightly scrape against a section of the rotor. I reversed the upper and lower retainers, and the problem disappeared. I'm guessing the two parts 'wore' differently over time.
Thanks again for the advice.
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
08 NBP TL
Sep 8, 2015 08:49 PM
jliu6789
Sep 8, 2015 08:02 PM
sputik
Sep 7, 2015 01:40 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
