Check TPMS - System Fault
Old 10-27-2009, 07:30 AM
cresus's Avatar
I was out driving the other day and went around a turn pretty quick and immediately afterwards got this TPMS error (not convinced they're related since it doesn't make much sense to me unless some wiring is loose). It stayed on for about 30 minutes (tire pressure was fine) but system wouldn't register any pressure on any tire. I called the dealer hoping this throws a code that's stored so they have proof that it happened but no luck. This concerns me if it becomes intermittent and the dealer won't do anything about it if it's not acting up immediately. Has anyone else experienced this and found the problem?
Old 10-27-2009, 06:09 PM
miner's Avatar
Just this past Saturday I got the code. Thought maybe air pressure was low since we had a cold snap. Checked tire psi with gauge and all was OK. The psi numbers would not register on the MID - just dashes. Took to dealer and the back left TPMS was bad. If one goes bad, the system throws an error code. Replaced under warranty.
Old 12-17-2009, 11:31 AM
30CL's Avatar
Was this under extended or original warranty?
Thanks.
Old 12-17-2009, 12:22 PM
miner's Avatar
Original warranty - in & out in 1 hr.
cycdaniel
12-17-2019 10:58 AM
bailey24
11-21-2015 08:43 PM
01CLOwner
10-09-2015 01:07 PM
SpraykwoN
ILX
09-23-2015 11:44 AM
GhostTL09
09-19-2015 01:57 PM
Quick Reply: Check TPMS - System Fault
