Changing HID
Old Jan 27, 2006 | 09:58 PM
gfd1182's Avatar
Changing HID
I know this is a repost but I can not find any info on how to change the HIDs'
Can someone point me in the right direction.
Old Jan 28, 2006 | 09:17 AM
xizor's Avatar
Bye TSX, hello domestic?
change what exactly? if you want to change the bulb out, just pop open the cover on the back and you should be able to swap them.
Old Jan 29, 2006 | 06:51 PM
gfd1182's Avatar
its that easy? so just screw the cover out. Do you use an allen key?
Old Jan 29, 2006 | 07:34 PM
tech123's Avatar
3rd Gear
to answer your question, there is a ballast in your lamp on either side screwed to the bottom of the housing. from there the actual bulb plugs into that unit and yes it is held in with a tamper resistant torx screw
Old Jan 29, 2006 | 07:36 PM
tech123's Avatar
3rd Gear
the actualbulb shouldn't blow out . there may be a problem w/ your ballast or the wiring.
Old Jan 30, 2006 | 09:05 PM
gfd1182's Avatar
no my bulb isnt blown i just wanted to upgrade, so how do i get that screw out?
Old Feb 2, 2006 | 10:31 PM
acuramech's Avatar
7th Gear
the easiest way to replace the hid bulbs to remove the front bumper cover and then the headlight assembly . does not take that long . and it is not called a ballast. it is an inverter and igniter. all in the same unit
Old Feb 2, 2006 | 10:49 PM
JTso's Avatar
You can remove the bumper and headlight assembly first if you want. But that's not the easiest way. The easiest way is to "simply" remove the rear cover (you need a security torx tip), then the bulb connector, bulb retainer clip, then the bulb. There is absolutely no need to remove the bumper.
Old Feb 2, 2006 | 11:44 PM
fuckleberry's Avatar
"inverter" is not shown as a separate piece in this pic right ?
Old Feb 2, 2006 | 11:49 PM
says so in the service manual
Old Feb 3, 2006 | 12:26 AM
arch's Avatar
Does anyone know the part # for the screw holding on the cover?
Old Feb 3, 2006 | 01:05 AM
JTso's Avatar
It's 33107-S0A-J01. You can just replace it with a normal screw, unless you really want that torx screw.
Old Nov 26, 2007 | 04:18 AM
blaqtsx's Avatar
had a question about that picture with all the parts. what is the part labeled 13 called?
Old Nov 26, 2007 | 06:52 AM
HoRRo's Avatar
iVTEC no koe
I believe it is called the HID Igniter.
Old Nov 29, 2007 | 04:17 AM
blaqtsx's Avatar
Ic, thanks. Do you think they would sell that part alone, and if it would be hard to install? I don't know what happened to mine but it looks really burnt somehow.. My lights been out for quite some time and I need to replace ASAP.
Old Nov 29, 2007 | 06:52 AM
HoRRo's Avatar
iVTEC no koe
Yes, you can purchase the part by itself. Not sure how hard/easy the install is, but it looks like a plug into the HID Control Unit and the HID Bulb sits in the D2S base. As long as you have access to the plug end, it would appear to be a relatively easy install.
Old Dec 13, 2007 | 12:37 AM
Ptown_tsXXX's Avatar
Does any one know where I can get a torx screw remover? Autozone? Well, any ways I been having a problem with my driver side headlight, which does not seem as bright as my pass. side. Could this be a bulb problem or my ballast? thanks in advance.
Old Dec 13, 2007 | 07:15 AM
Simba91102's Avatar
Old Guy
Torx head screws are fairly common now and you could probably find a set of drivers anywhere that sells tools (even Wal-Mart). They come with a handle like a regular screwdriver or you can buy a socket set to use with a ratchet or driver (Craftsman for instance has quite a variety). I have a set that are sized 10,15,20,25,27 for use with a 1/4" drive ratchet and size 30,35,40,45,50, and 55 for use with a 3/8" drive ratchet. The numbers don't seem to signify anything (that I can tell anyway) other than the bigger the number, the bigger the Torx head .
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
Silverstead1
Sep 17, 2015 06:45 AM
Aleax
Sep 11, 2015 11:31 AM
