car vibration
car vibration
Ok quick question 2006 tsx when you have motor running and sitting there the car is perfectly smooth but you put it in any gear then you get a really bad vibration in car what to look for?
I did replace awhile back the front, rear and side motor mounts but not genuine acura but they did say they were all hydraulic. what should I look at next?
Thanks!
Thanks!
If idle speed is going low (< 600 rpm), vibration may occur. Idle speed in gear should be about 800 rpm. Low idle would be caused by too little air passing throttle plate.
Cleaning throttle plate and bore may help. Careful not to force throttle plate open manual (use gas pedal w/ keyswitch On to open for cleaning).
good luck
good luck
Thanks!
Thanks!
Thanks!
Thanks!
I had the same problem, I bought cheap Amazon mounts and the problem got worse, I ended up replacing the front engine mount with a genuine Honda mount and my car runs smooth again.
