Car shakes after new engine mount?
Old Dec 21, 2014 | 10:18 AM
sho0z's Avatar
I had a shop change out one of my engine mounts. The problem was severly worse after they were done, I thought this would correct itself but did not after a few days so I took it back. They took a look at it and may have tightened/loosened the correct torque specs or something because it was just fine for about 3 months. We then moved and I had my car on a flatbed transport and I had issues getting the car on/off since it was so low. Now the severe reverb from the exhaust and shaking is back. Does anyone have any suggestions as to how I can self remedy/check this? Car is 2004 TSX.
Old Dec 23, 2014 | 12:18 PM
sho0z's Avatar
anyone?
Old Dec 23, 2014 | 01:05 PM
you'll need to check your self to see if anything in the engine bay is out of place.
look at all mounts, all bolts, everything.
Old Dec 24, 2014 | 08:37 AM
curls's Avatar
Someone stole "My Garage"
Were they OEM mounts that were replaced? If not... you likely got aftermarket ones that are as hard as bricks.
I made the mistake of getting "Anchor" brand, which even had an OEM part number stamped in the rubber. The car was vibrating worse at idle than when I had the Ingalls 'stiffy' dampener and an OEM front and rear engine mount!
Old Dec 24, 2014 | 08:44 AM
Tangoman's Avatar
I have a lot of experience with this. I was taking out and changing my tranny anyway, so I did all 3 mounts while it was dropped. The front one is the most critical for NVH (noise, vibration, harshness). I had aftermarket ones in all 3 locations "Anchor brand" and it was terrible. So I switched the front out with a Beck/Arnley. Fixed the vibration issue in warm weather. It still has the vacuum line attachment on it. But, the rear I kept as an aftermarket one - in the winter it does get loud and shakes the car, but in the summer its the perfect balance of sporty and soft. I actually like how it ended up.
If you want to keep the comfort of the stock car, we've tried it, you need OEM mounts or high quality aftermarket parts - if the front mount costs less than 100 bucks somewhere you're not buying a good mount.
Old Jan 3, 2015 | 09:36 PM
Cl9Driver's Avatar
6th Gear
Have any one tired moog replacement mounts?
Old May 1, 2015 | 07:10 AM
budah1999's Avatar
Use Oem mounts and your problem will go away, I had the same issue after using aftermarket mounts
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
datadr
Sep 2, 2015 06:46 PM
