car shaking
car shaking
hi, just last week, i noticed that my car shakes and vibrates consistently while i was driving on highway or road. wondering why? the car has only about 800km. it seems to be like tire or wheel issue. i got headaches after i drove home that night due to all the shakes after got off the highway. and it feels fine the next day i drove the car. why does it happen? anyone has the same experience?
Originally Posted by say what?
does it only happen when you go over about 90 km/h???
possibly snow in the rims... happened to me...
just clean out the snow and should be good as new...
Bring it back to your dealer since it's still under warranty and have them check it. The wheels probably needs to be rebalanced!!! If that's the case than you should bitch at them how you paid for PDI but it doesn't seem like it was done at all.
hi
for sure the cases are many..........
what i can say from practical experience is the factory MICHELIN rubber is not the greatest(just my own opinion). the design uses alot of nylon,and yes,will "flat spot" simply from the car sitting way too long.
this usually works it's way out the more you drive.
as well,dealer's doing really poor PDI'S is a verified issue with ACURA.
i picked my car up,the washer fluid was empty(no big deal),shipping plastic here and there, etc...... and the tires were all set at 42 psi (note: tire pressures are set high at the factory to avoid flat spotting)
nothing like paying for a PDI done by the invisible lot guy!!!!
cm
cm
Originally Posted by Bizzenn
i had the same problem. The tires have flat spots when there new. After 1500 miles the shaking will be gone
The tires are set at high PSI (over 40 instead of 32 front/30rear) for transit purposes and to prevent flat spotting. This person probably has tire imbalances unless the tire pressures are seriously low.
Go to your dealer, have them test drive it, and let them figure it out. This is an easy one.
Originally Posted by kurt_bradley
Um, no, they don't. Keep that kind of posting up, and I'll take away your talking priviledges for the day.
We just got 8 inches of snow here overnight, and mine started to do the same thing: significant shaking and vibrating at highway speeds. The funny thing is it hasn't happened before following earlier snowstorms. I am hoping it is only snow related and will go away soon on its own or with a little bit of manual snow search-and-removal.
