Car jerks
Car jerks
Hello everyone,
I have a 2005 TSX, automatic. Lately, I've noticed my car is jerking when I am slowing letting off the brakes. For instance, when I am inching up during traffic or at a stop light, I have the brakes engaged but not fully. In other cases where I accelerate normally, I don't have this issue.
Anyone have any idea where to start looking?
Warped brake rotors can result in uneven brake pad release, or possibly a sticking caliper pin is causing rough action. Inspect brake rotor runout and caliper pins.
good luck
good luck
Thanks for the feedback. I recently replaced both rotors and pad in the front and just pads in the back.
The jerky feeling is very similar to what I felt when my ignition coils went back.
Kinda hard to assess with a butt diagnosis and no check engine codes.
Or as the other poster indicated, double check your brake job.
Sounds to me more like some engine/trans mounts going bad. Mine is doing nearly the same thing, have all mounts ready to put in.
The TSX only has 6 motor/trans mounts to go bad at least...
Preout
11-23-2015 11:12 AM
