Can't REV Engine over 5k when trans in park?
Old Feb 1, 2006 | 02:12 AM
CyKam's Avatar
8th Gear
Hi everyone.
I came across something today on my 04 TSX 5AT. here's what happen. after a nice dinner out, I got in to my TSX and start it like normal. Crank.crank crank. the enging won't start. then I did it a again. (Crank it longer then normal) but this time the engine starts. so it let the car idle for a bit then just give it some gas while the transmision is still in Park. but I have notice that the engine can't rev over 5000rpm. it's like there's a gas cut off at 5000rpm.?? what wrong? is there a rev limit on the engine at 5000rpm when the tranny is in park?
any help would be great. i just want to see if this is normal before i call the dealer.
Old Feb 1, 2006 | 02:21 AM
leftride's Avatar
i want to ride my bicycle
its normal.
why would you be revving a parked car higher than 5k (not to even mention one thats not warmed up)
oh and welcome to the forum
Old Feb 1, 2006 | 02:22 AM
CyKam's Avatar
8th Gear
Update.. more info.
I just went out again and start up the car to see is it stil does it. the engine is still warm. then same thing happen. the engine would rev to 5k-5500rpm and drop back down to about 4800k and up again..
Old Feb 1, 2006 | 02:24 AM
CyKam's Avatar
8th Gear
Originally Posted by virus7
its normal.
Thanks. I rev the engine because the engine is idling really rough. I only went in for dinner for about an hour. and the engine is still warm.... so there is a rev limit i guess.. this is my first honda that does that.
Old Feb 1, 2006 | 02:27 AM
fuckleberry's Avatar
Just how cold was it ?
Old Feb 1, 2006 | 02:31 AM
CyKam's Avatar
8th Gear
it's pretty warm. about 16°C outside temp. parked in undergrand parking for 1 hour, after a 30 min highway drive...
Old Feb 1, 2006 | 06:39 AM
lcrazyaznl's Avatar
CL9 ABP
Theres really no need to rev at all, I just let the car warm up a bit till the engine has lowered to like 600 rpms and slowly take the car out till the temperature guage moves up then I drive more agressively.
Old Feb 1, 2006 | 06:40 AM
moda_way's Avatar
Originally Posted by CyKam
Hi everyone.
Do a search, but it isn't supposed to rev over that. First of, it isn't good to rev a motor... it isn't meant for that.
You need to diagnose the issue of why it won't start... reving it won't solve that issue.
Old Feb 1, 2006 | 09:57 AM
jlukja's Avatar
The AT, when in neutral, has a fuel cutoff at 5Krpm. I think its because its bad for the engine to be revved that high without load on it.
Old Feb 1, 2006 | 10:10 AM
moda_way's Avatar
MT has the fuel cutoff too.
Old Feb 1, 2006 | 11:13 AM
so the fact it did not start right away doesn't concern you ?
Old Feb 1, 2006 | 12:09 PM
CyKam's Avatar
8th Gear
okay. then there's a rev-limit on it. that's good to know. so now I have to get the car checked out for hard starting.
Old Feb 1, 2006 | 12:20 PM
moda_way's Avatar
You are forgetting the point that you shouldn't rev like that either. If your car can idle smoothly, just take it in. Revving it does nothing.
Old Feb 1, 2006 | 12:22 PM
jlukja's Avatar
Its there to keep you from doing neutral drops at 7300rpm.
Old Feb 1, 2006 | 03:21 PM
dzuy's Avatar
Troutslap Mod-DUH-rator
MT doesn't have a park tho
Old Feb 1, 2006 | 03:29 PM
lcrazyaznl's Avatar
CL9 ABP
Sometimes if you dont hold the key on the car won't start on a cold day, maybe check the sparks plugs.
Old Feb 1, 2006 | 06:34 PM
jerzpwr's Avatar
i thought this was due to some kind of emission thing. Like the car trys to start the car with the lowest possible emission output.
Old Feb 1, 2006 | 07:04 PM
moda_way's Avatar
Yeah and thank god for that!!!
Old Feb 1, 2006 | 07:07 PM
moda_way's Avatar
No, it is so numbnuts stop over revving their motors with no load on them.
Old Feb 1, 2006 | 08:11 PM
aaronng's Avatar
Driver/Detailer
Before you turn your engine off, let your car idle for a few seconds until your RPM drops from 800-900rpm to 600-700rpm. Then turn it off. The hard starting probably comes from the combustion chamber being wet with fuel when you turn your engine off immediately after you stop. It happens to my car too.
Old Feb 2, 2006 | 06:41 AM
moda_way's Avatar
Interesting, I've never heard that before. I know it is better to have the car at operating temp then shutting it of, but that had more to do with getting the spark plugs up to self-cleaning temp than anything else.
Old Feb 2, 2006 | 10:37 AM
CCColtsicehockey's Avatar
so true so true
Old Feb 2, 2006 | 02:48 PM
CyKam's Avatar
8th Gear
Yes yes, i won't rev it anymore. I'm just so used to my B18 Crx.
Old Feb 2, 2006 | 04:09 PM
moda_way's Avatar
You'll love the K24, just not the DBW.
Old Feb 3, 2006 | 02:58 AM
CyKam's Avatar
8th Gear
I like the K24, it's just that I'm really not use to driving a AT. and also the DBW. It feels like I don't have full control of the car sometime. but now. I can do a lot more while i'm driving. like read the paper's on the way to work, drink coffee, watch a DVD, shave.... just kidding. I'm a safe driver.
justin7779
Dec 25, 2015 10:33 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
carz0159
Sep 20, 2015 06:11 PM
Sep 14, 2015 03:16 PM
Mike Bertram
Sep 10, 2015 09:27 AM
