Can someone post TSB 06-039
I can get it from Alldata, but it is 7 pages of diagnosis and corrective actions. Basically, it is a steering wheel and/or wheel alignment issue. No reason is given why, just that a bunch of steps need to be taken to diagnose what the issue is.
What more specifically do you need?
Juice!
The short of it is that my car only has 19000 miles on it, never been in an accident or hit a pot hole or a curb. But the left rear had gone out of alignment and the dealer claims that they cannot get it perfectly aligned.
They say that the best they could with the camber is a couple of degrees off, and this is due to either a bent chassis, control arm, or trailing arm. They want to put the car on a frame machine to find out exactly what is bent.
Anyway, in searching around in here I found references to TSB 06-039 when alignment was involved and I wanted to see if it is of any help to my problem.
Originally Posted by OhNoItsMe
Hi Moda,
This would only apply for a steering/pulling issue. This TSB involves making sure the steering wheel is aligned properly.
Originally Posted by NJTSXMan
This seems to be my problem. My car has always had a pulling issue and I even had the rear tsb done as well. Ever since then the steering wheel has never been straight even after repeated attempts to get the car aligned. The steering wheel would have to be slightly tilted to steer straight.
What model years does this TSB affect? Does it affect a certain vin range? What is the title of the tsb? thanks.
Juice!
Hi Moda,
Is TSB 06-039 only for front alignment issues or is it for rear also?
Do you mind posting it or posting a link to it? I would really like to take a look at it.
Chris
Here's all the forum postings on this issue, has anyone figured it out?
http://www.acura-tsx.com/forums/show...699#post683699
https://acurazine.com/forums/showthr...ight=alignment
https://acurazine.com/forums/showthr...ghlight=06-039
It is the exact same info posted here under 06-034 (not sure if that was a misprint):
https://acurazine.com/forums/showthread.php?t=24738
EDIT: 06-034 and 06-039 look EXACTLY the same to me, so I'm not sure why another one was issued unless it included additional models.
Originally Posted by jlukja
06-039 is for the RL regarding the Navi system losing GPS signal.
Wed, Oct 25, 2006 Sat, Oct 7, 2006 06-039 Steering - Vehicle Pulls Left or Right
Acura
Posted: Wed, Oct 25, 2006
Issued: Sat, Oct 7, 2006
TSB Number: 06-039
Title: Steering - Vehicle Pulls Left or Right
Mon, Jan 22, 2007 Fri, Jan 12, 2007 06-034 Steering and or Suspension - Vehicle Drifting and or Pulling
Posted: Mon, Jan 22, 2007
Issued: Fri, Jan 12, 2007
TSB Number: 06-034
Title: Steering and or Suspension - Vehicle Drifting and or Pulling
Sorry to bring back an old thread. I just called Springfield Acura in NJ about TSX 06-034 (steering wheel pull issue), and they said that this is not covered under warranty and it costs about $100 just to take a look at it. I thought it would be free since my car is still under warranty. Or maybe I am just a complete noob at these things.
Originally Posted by cwh82
I actually just called Acura Client Services (1800-382-2238). The rep took my Vin number and told me that my vehicle does not qualify for this TSB. Am I missing something here?
According to the TSB, after they check the alignment and roate the tires, if the problem persists, they can adjust the steering wheel. I have had my alignment done plenty of times and had my tires rotated. I am almost positive my steering wheel is off center. What exactly is involved in straigntening out the steering wheel?
Eggs999bacon
09-24-2015 10:08 AM
