Camshaft Position Sensor
Old May 2, 2007 | 09:59 AM
Coomofo's Avatar
My 04 Tsx Engine check light came on and i got it checked out. They said its my camshaft positioning sensor. Will that affect my car starting? Ive had to get it jumped three times already. I try to start it and all i hear is "Click, click, click, click, click" also when i drive it the performance seems to be slugging. And to add more on it i can be driveing and all off a sudden the VSA light will come on. This ever happen to anybody?
Old May 2, 2007 | 10:34 AM
joerockt's Avatar
Just dial 1911
Well if jumping it is starting the car, then it cant be the sensor. So either your battery is going or its the alternator.
Old May 2, 2007 | 06:09 PM
Jerome81's Avatar
I would say that yes it could affect your starting.
The CAS tells the computer where the crankshaft is in its rotation. Using the crankshaft position, it tells the spark plugs when to fire.
If the CAS is defective it could be telling the plugs to fire too early or too late. Might be especially noticably during cold starts and would DEFINITELY affect power. Retarded timing will decrease power.
Wouldn't surprise me if it is all related.
Old May 2, 2007 | 07:23 PM
darcheeseTSX04's Avatar
It does sound like the battery is also bad too. Im not an expert, but it doesnt hurt to wiggle some wires and make sure they are all tight.
Old May 2, 2007 | 09:04 PM
joerockt's Avatar
Just dial 1911
So how is it that when he gets a jump, the car starts?
Old May 2, 2007 | 09:08 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Ask them for the CEL code. What DTC did it throw?
Old May 2, 2007 | 09:28 PM
mercman's Avatar
It really sounds like multiple problems,
First, the crankshaft sensor and related wiring can cause an intermittent crank but no start condition. However, when you get the “click click” that indicates a bad (week) battery or bad connections (ground and/or +). A bad or week battery can also cause things like ABS/air bag and VSA indicators to flash.
I would start with a battery and charging system load test and an inspection of the battery cables.
When you get it to the point where it cranks but won’t start or it doesn’t always start then look at the crank and cam sensors.
I have replaced a few intermittent sensors in the past.
jeff
MrHeeltoe
20
Feb 23, 2023 01:54 PM
RobbDizzle
Oct 15, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
