Cabin Air Filter Change - need help ASAP!
Old Jan 11, 2012 | 07:56 PM
JeffTSX021's Avatar
Hi guys!
I am trying to replace my cabin air filter on my 07 TSX. I am able to access it and release it, but when I try to pull the tray out, it keeps getting caught up on the black vertical bar with a white sticker on it that runs horizontally just above the tray. Can someone help me, please? I really don't want to pay a dealer to do this!
Thanks!
Jeff
Old Jan 11, 2012 | 08:42 PM
Jdmhoes's Avatar
Have your glove box opened and you'll see two plastic tabs and the rubber stopped on the outterside. Push those tabs so they fall into the glove box. Once those are off the glove box will fall down completely and you will be able to access your filter change.
Old Jan 11, 2012 | 09:12 PM
npolite's Avatar
Not sure where the problem could be. Perhaps someone didn't install the filter correctly the last time? Keep pulling on it and if you end up breaking the plastic housing, it shouldn't be that much to replace it.
Normally once you remove the front cover it should slide out with a little wiggling.
Old Jan 11, 2012 | 11:15 PM
JeffTSX021's Avatar
Thanks guys! I'm not sure what the problem is either. I will take a photo of where the tray is getting caught up tomorrow.
I just wanted to make sure there wasn't something I had to trim or cut before removing it for the first time. Although, I am pretty sure Acura has replaced that filter for me before.
Old Jan 12, 2012 | 12:28 PM
miner's Avatar
I believe the first replacement does require cutting a black plastic bar.
Old Jan 12, 2012 | 03:46 PM
swoosh's Avatar
takin care of Business in
hahahah guess Acura didnt change it for you before....
Old Jan 12, 2012 | 07:50 PM
JeffTSX021's Avatar
Ha! I guess NOT!
Can anyone confirm for sure that you DO cut a black plastic piece?
Thanks much!
Old Jan 12, 2012 | 08:30 PM
swoosh's Avatar
^^^ Thats why i never go to dealerships....
but yeah u gotta cut the tab when you do it for the first time
swoosh's Avatar
Old Jan 12, 2012 | 08:32 PM
JeffTSX021's Avatar
Ok, thanks for confirming!
Also, stupid question... but, what did you use to cut it with?
Anyway, I'm glad I paid a fortune to have Acura do absolutely NOTHING! Hence the reason why I'm going to start doing it myself!
Old Jan 12, 2012 | 08:36 PM
swoosh's Avatar
use a dremel
I just took a sharp nice to it
Old Jan 12, 2012 | 08:37 PM
swoosh's Avatar
use a dremel
I just took a sharp knife to it
Old Jan 12, 2012 | 08:43 PM
JeffTSX021's Avatar
I don't have a dremel, so I guess I'll be using the sharp knife method as well
How long did it take you to cut through it with the sharp knife?
Old Jan 12, 2012 | 08:46 PM
swoosh's Avatar
i just heated the sharp knife and cut the tab....
remember you just gotta cut a 2mm tab....not the whole thing....just wanted to clarify LOL....
swoosh's Avatar
Old Jan 12, 2012 | 10:09 PM
JeffTSX021's Avatar
You don't happen to have a picture of the tab that needs to be cut do you?
I just want to make sure I cut the right thing. What color was it?
Old Jan 13, 2012 | 06:12 AM
npolite's Avatar
This is strange, I even looked at the service manual and it doesn't mention anything about cutting any tab. I can even take a screenshot of the page if you would like. I bought my car used with only 23k miles so I don't know if it was ever replaced but I can tell you I never cut any tabs.
Old Jan 13, 2012 | 06:18 AM
miner's Avatar
Have you checked the owners manual on replacing the filter?
Old Jan 13, 2012 | 06:22 AM
JeffTSX021's Avatar
I don't have a service manual. Can you take a screen shot for me?
Thanks!
Old Jan 13, 2012 | 08:21 AM
RA032025's Avatar
in the 24th and a half...
Service manual shows no cut...
I replace all filters myself and NEVER CUT a thing. DON'T CUT!
Open glove box ALL the way (includes popping out the arm and the two restraining roller thingies)...squeeze the tabs and remove. In my case, push the cable bundle out of the way...and it pulls right out.
Old Jan 13, 2012 | 08:33 AM
supafamous's Avatar
Here's a DIY vid on how to do it.
Old Jan 13, 2012 | 12:18 PM
swoosh's Avatar
^^^ even the first year of the TL (2004) there was a tab on each side you had to cut....
am trying to find that link....i remember cutting the tab in my friends 04....my 05 did not have a tab to cut.....
Old Jan 13, 2012 | 02:11 PM
npolite's Avatar
Here is the image from the service manual. This covers the TSX from 04-07. You just need to press in on the two tabs to pull the tray out.
http://i39.tinypic.com/nlenp5.jpg
Old Jan 13, 2012 | 02:43 PM
JeffTSX021's Avatar
Hey guys, I figured it out! I wasn't pulling hard enough on the tray. Anyway, both my engine air filter and my cabin air filter are now changed!
Thanks again for all of your help!
Old Apr 27, 2012 | 11:04 AM
bulterier's Avatar
Listen to DuckRodgers on this.
Do NOT cut anything when replacing the cabin filter. The only thing you need to do is loosen the two gove compartment stops (one on each side) and have them drop inside the compartment. That will allow the glove compartment lid to drop further, allowing acces to the filter.
The only time you need to cut is when you are removing the blower unit. Such as when you are accessing the expansion valve.
Old Apr 27, 2012 | 04:55 PM
SoCaliTrojan's Avatar
Let me help you!
I read the thread from the top. If you could see my face as I was reading the thread, I became more and more confused when everyone kept saying to cut something. Acura has never replaced my filter (I do it myself), and I have never had to cut anything.
The only time I have ever needed something cut was when working on a 2004 Honda Odyssey...but fortunately the dealer had done it already by the time I got to it.
Old Apr 27, 2012 | 05:37 PM
bulterier's Avatar
Just know that the only time you will see the preformed cut areas on the lower sides of the Glove compartment is when you actually remove the gove compartment door. Now if you have removed, and your object is to remove the cabin filter, then I see no reason to cut the areas and remove the center section. (note - on doing this, you will have to get an addtional two screws to mount the now cut center section back in place.
Here is the link from above that actually shows the two areas to be cut. http://api.viglink.com/api/click?for...13355659354333
Perhaps this will help explain what is being talked about above.
Old Apr 29, 2012 | 04:14 AM
Simba91102's Avatar
Old Guy
Boy, way to make a mountain out of a mole hill. For anyone interested in how to replace the cabin filter, you need only to read post #25, the rest can be ignored (they'll only confuse you). This of course assumes you've done as I do and go to the last post and work your way back (so you've read this one first).
Old May 18, 2012 | 11:34 AM
skidder's Avatar
9th Gear
Thanks for the tips. I just replaced my cabin filter this morning, with a Bosch P3875 premium filter purchased through Amazon (which didnt fit properly-it was 1/8 inch to long-I had to trim and mash to the point it may not seal properly).
I would add that when pulling the filter tray out, the side clips should be pressed inward, not outward (as I first tried to do).
Abe_Froman
Sep 16, 2015 01:27 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
Aleax
Sep 11, 2015 11:31 AM
Aleax
Sep 9, 2015 08:04 PM
bymotion
Aug 31, 2015 05:00 PM
