Broken Glove Compartment Shock :(
ASM 3G TL Type-S
I tried replacing my cabin air filter also…inspired by the 'Why you should change your cabin, pollen filter' thread, lack of reading and knowledge on my behalf I managed to break the ‘shock’ that compresses, and makes the glove compartment slide down easily. Anyone know how much the part would be or what part # I am looking for? Would I be able to change this myself? Or is the dealer going to charge major $$.
Should I live with this, since I dont use my glove box that much anyway?
I have the parts diagram for the glove box assembly (with part numbers), but I'm not sure what part is it that you need. You should be able to take the part to an Acura dealer and have them get you a replacement. If you got it apart to change the filter, I'd think you should be able to replace the broken part.
If youre talking about the damper, through the stealership it will cost around $20. I'm friends with mine so they give me the wholesale list price which is $8.25, it says MSRP is $11 but dealers usually jack up the prices. Heres the diagram.
oemacuraparts.com/partlocator/index.?action=getJointLocator&siteid=214055&chapte r=&Sectionids=0,2610&groupid=2640&subgroupid=4577& componentid=0&make=1&model=Tsx&year=2007&graphicID =4830275&callout=5&catalogid=2&displayCatalogid=0
ASM 3G TL Type-S
Never mind guys I got the link to work for me, I might undergo this one myself $20 dollar part acura charges 30 somewhat dollars a hour, do I began access with the passanger side door open, to unvail the access panel? any ideas on how I would go about removing + installing?
If you take your time, and are fairly careful about removing the pieces that hold the glove box door in place, it's an easy job that is for the most part self explanatory as you proceed. Just keep track of the pieces for reassembly and you'll be all set.
dirleton
Aug 6, 2024 08:19 PM
mlody
Dec 4, 2019 02:11 PM
dainmezron
Oct 16, 2015 06:56 PM
