Broke a wheel stud >=(
Old Jul 29, 2004 | 05:51 PM
xizor's Avatar
Bye TSX, hello domestic?
So I'm driving home from work today and hear a really loud clanking noise from my front left wheel. I'm thinking ah crap, I screwed up something installing my springs yesterday. I pull over and look and 3 of the 5 lugs are loose and one of the bolts is broken off completely. Amazingly the lug was still in the hole, just not attached.
This doesn't really surprise me because I torqued my lugs yesterday after installing a spring, and you're supposed to retighten aftermarket lugs because they can come loose. well that was @#%% fast, 1 day and 20 miles, never had that problem before and I've removed my wheels 8-10 times before.
Anyways, my real question is replacing the bolt that broke off. Acura lists 4 bolts that could be the one I need.
017 90113-SA0-006 BOLT, WHEEL 10 2004 Acura TSX 4.07 3.46 Qty:
017 90113-SA0-025 BOLT, WHEEL 10 2004 Acura TSX 4.07 3.46 Qty:
017 90113-SM1-005 BOLT, WHEEL 10 2004 Acura TSX 0.70 0.59 Qty:
017 90113-S5H-005 BOLT, WHEEL (THAI MEIRA) 10 2004 Acura TSX 3.12 2.65
Each can be seen on Sunnyside Acura's website under the front brake diagram. I can't find the diagram in my Helm's manual. Anyone happen to know?
I'll hit up my Acura dealer tomorrow anyways, but trying to be informed when I go since I not betting they would know the difference either.
Old Aug 14, 2004 | 12:18 AM
xizor's Avatar
I ended up buying a stud from my dealer, was about $5. I start to do the install, but couldn't get off one of the screws on the hub which the helm's manual says is torqued to 120ft/lb!!! I bought an impact screwdriver and will probably tackle it next week.
Old Aug 26, 2004 | 12:15 AM
xizor's Avatar
ok, keeping an ongoing thread in case anyone ever has this same crappy problem.
to take off the rotor all you do is:
remove wheel etc.
remove 2 bolts holding the caliper to the hub (top and bottom), hang the caliper with a coat hanger
unscrew the 2 screws in the rotor, you probably need an impact screwdriver
and you're done. however to remove the studs, you need to take the hub off the axel, which includes taking off the giant nut. I haven't figured out what the size of the axel nut is yet, but I believe its 36mm as I've tried 32 and 34 and neither fit. Taking off the axel nut will have to wait a little bit however.
Old Aug 26, 2004 | 12:20 AM
jmathew34's Avatar
if you could post some pics that would be helpful!!!
Old Aug 26, 2004 | 12:23 AM
JTso's Avatar
Damn! how much torque did you use to tighten the lug nuts?
Old Aug 26, 2004 | 01:53 AM
Stokeless_TSX's Avatar
Stokeless
haha johnny lol
Old Aug 26, 2004 | 07:36 AM
xizor's Avatar
didn't, lug came loose while i was driving and the wheel put enough pressure to snap it off
Old Aug 29, 2004 | 09:18 AM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
You shouldn't need to take the hub off, just knock the stump out and install the new stud- hint a few large washers and a new lugnut with a flat side to seat. It should take less then 15 minutes. FWIW the hub isn't going to just fall off when you remove that nut, there is a pressed in bearing which you will need a slide hammer to remove at which time you will probably rip the inner race out of the bearing. So just do it with the hub in place, its really much easier.
Old Aug 29, 2004 | 09:52 AM
xizor's Avatar
got there, tried that. there isn't enough clearence to remove the stud out of the back of the hub. it has to be removed, or the knuckle has to be cut. i prefer the removing it.
Old Aug 29, 2004 | 12:54 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
that's a bummer, I haven't done any studs or front end work on any TSX's yet to have any other insight. It looks like if you grind a flat side on the new stud it may fit, however its hard to tell from the picture. But be warned when you remove that nut the hub isn't going to come off easily, its going to fight!
Old Jul 21, 2007 | 12:18 AM
euro argh's Avatar
does anyone know the length of the stock wheel stud?
i'm looking to get extended studs and they have a 35 and a 45
don't want it to stick out too much
cycdaniel
Dec 17, 2019 10:58 AM
obert
Nov 14, 2015 09:59 PM
DUECE_DXJ
Sep 24, 2015 04:54 PM
jmoney2001
Sep 11, 2015 12:07 PM
mtl_ilx
Sep 3, 2015 09:48 AM
