Bright headlight
Old Jun 2, 2006 | 02:37 AM
Masterpoolcat's Avatar
Bright headlight
One of my headlights is brighter than the other. Is there a way to correct this? I have not made any changes the headlights. Any help will greatly be appreciated. Thanks.
Old Jun 2, 2006 | 05:36 AM
moda_way's Avatar
Also, remember the lights are not aimed the same, so you could just be mistaking the fact you are seeing one directly on and not the other.
Old Jun 2, 2006 | 09:23 AM
cibs's Avatar
is this from your observation while you're driving the car? or when you're looking at the car head on... if you're looking at the car head on then it's most likely what moda said...
*dito to the pics...
Old Jun 2, 2006 | 10:33 AM
I'll take a couple of pics tonight. My observation is from both, when I'm driving the car and also when I'm looking at the car head on. The driver's side light is much brighter. I also notice when I'm driving that alot of the on comming traffic covers their eyes because they get blinded by my lights. Alot of drivers flash their high beams at me to signal me that I have my high beams on, but they're not. Whenever I would pick up my girlfriend, she said she knew it was me comming because the driver's headlight was brighter.
Old Jun 2, 2006 | 11:34 AM
Dan Martin's Avatar
Photography Nerd
It's unusual for the driver's side to appear brighter. It should be aimed lower than the passenger side so it will appear darker. Take a shot with your lights aimed at a wall so we can see the beam pattern. it should look something like this _____/----------
Old Jun 3, 2006 | 04:03 AM
OK guys, here are the pictures! As you can clearly see, the drivers side headlight is brighter than the other.
About 10 feet away with flash
about 10 feet away without flash
about 10 feet away with flash
front view with flash
front view without flash
about 40 feet away without flash
about 40 feet away with flash
Please help! Is there any way to correct this?
Old Jun 3, 2006 | 04:32 AM
n3ok318's Avatar
to me, neither headlights appear to be "brighter"
i believe you need to adjust the height of your driver side headlight slightly lower than the passenger side. Otherwise you might be blinding oncoming traffic
Old Jun 3, 2006 | 04:47 AM
xenonhid's Avatar
CGP Ebony
My Eyes says that your bulb looks ok, but the height on the drivers side HID is higher than it should be = Lower the drivers side HID
Old Jun 3, 2006 | 05:53 AM
feelgood13's Avatar
your headlights are seriously unaligned. did it come like that? do you see how you have two distinct cutoffs? you need to adjust and lower the driver side headlight
here's info: http://https://acurazine.com/forums/...ad.php?t=21758
Old Jun 3, 2006 | 06:19 AM
Adamantiium's Avatar
^link is messed up
just to make it easier, ill repost the instructions on here
Old Jun 3, 2006 | 12:02 PM
waTSX's Avatar
Have camera, will travel
Yeah, it looks like more of an adjustment problem to me.
Old Jun 5, 2006 | 02:53 AM
Thank you so much for the help guys! You guys were right! All it needed was some adjusting. Thanks again!
Old Jun 5, 2006 | 03:35 AM
feelgood13's Avatar
Don't thank us, we're sending you a bill...
Old Jun 5, 2006 | 06:55 AM
LoveMyTL-S's Avatar
Looks like another satisfied customer
Old Jun 5, 2006 | 08:20 AM
GIBSON6594's Avatar
My Garage
Pics of said girlfriend will be fine...kthanks
Old Jun 5, 2006 | 11:32 AM
waTSX's Avatar
Old Jun 5, 2006 | 11:42 AM
jlukja's Avatar
Old Jun 5, 2006 | 12:46 PM
ILoveMyHonda's Avatar
17781708
I love this place, keeps me sane at work!
Old Jun 5, 2006 | 08:46 PM
LoveMyTL-S's Avatar
Me too
Old Jun 20, 2006 | 01:38 PM
hageemah's Avatar
I have the same problem as him, with the exact same beam pattern(really high on the driver side), however the driver side can go higher and can go lower, but only low enough to a certain point which is still too bright. anyone else know how to fix this? will pay if i have to! thanks
Old Jun 20, 2006 | 03:38 PM
xizor's Avatar
Bye TSX, hello domestic?
if the problem is one is brighter than the other, then raise the passanger side so they'll be the same brightness. if the problem is the driver side is too high, well then you have a problem
Old Jun 20, 2006 | 03:46 PM
hageemah's Avatar
yah the driver side is too high. i might have aproblem.
Old Jun 21, 2006 | 04:56 PM
Are you sure that it's too high? Did you make sure to do the measurements in the instructions? I remember when I first got my car I thought the lights were too high also (that is before they got out of alignment).
Off topic: Alright guys! Here is the pic of my said girlfriend. She's the one on the far left. Her friends are available and I could introduce you guys. Keep your pants on and the drooling to a minimum please.
Old Jun 21, 2006 | 08:06 PM
feelgood13's Avatar
Nice! which one is yours?
Old Jun 22, 2006 | 02:21 AM
The one with no underwear on!
Old Jun 22, 2006 | 03:25 PM
hageemah's Avatar
yah i'm for sure it's too high. it's glaringly bright at 40 feet while standing.
Old Jun 22, 2006 | 10:26 PM
SoCaliTrojan's Avatar
Let me help you!
Sounds like the headlight assembly wasn't installed onto the body correctly. The adjustments should only let you adjust them for a certain range...if it's too high at the lowest adjustment, then it sounds like the headlight assembly wasn't installed onto the body correctly.
Old Jun 22, 2006 | 10:48 PM
xizor's Avatar
honestly I think its probably a user error, if you're not familiar w/ HIDs and the cutoff or don't know how to properly adjust the headlights, it'd be easy to think theres a problem. I suggest taking it to the dealership to get it checked, either way it'll get fixed
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
eastcoastguy
Sep 23, 2015 06:29 AM
