Brakes dragging or binding?
Old Aug 22, 2011 | 06:09 PM
Castles_Saloon's Avatar
I'm a rookie to brakes. Last night, I replaced my rear brake pads and rotors. I spun the hub and it moved freely. Then I depressed the brake pedal a couple times, then check the hub again and it was making rubbing sounds (shh ... shh ... shh ...).
I followed the service manual for the most part (didn't the specified grease) and took a peak at some posts for similar issues, but the solution is not obvious yet.
What do you think may be causing the rubbing?
Old Aug 22, 2011 | 08:51 PM
main70072's Avatar
When you depressed the brake pedal, it caused the piston to come into close contact with the pads. It's normal, as long as it's not binding forcefully. Rotors are not always perfect, and the sounds that you hear are from the pads scrubbing the uneven spots on the rotor.
Old Aug 25, 2011 | 03:35 PM
invalidalias's Avatar
This seems to happen a lot with new rotors. The surface finish isn't smooth. Should go away over time. Drive the shhhhh out of it and after a while it won't make any noise
Old Mar 23, 2012 | 07:08 AM
Redflem's Avatar
3rd Gear
Just solved my problem in 10 seconds. I love old posts.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
polish_pat
Sep 30, 2015 12:22 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Froid
Sep 27, 2015 06:16 PM
