brakes brakes brakes
I'm beggining to think mine have warped as well. There's alot of shake (vibration) as soon as the pedal's depressed or when braking hard from higher speeds. I'll mention it to the dealer this weekend.
Photography Nerd
Domn, here's an interesting article about "warped" brakes by someone who knows a lot about brakes: http://www.stoptech.com/whitepapers/...otors_myth.htm
Photography Nerd
I think they are trying to show a dented rotor where the face has collapsed around the internal structure. To me, the word "warped" means that the whole rotor is bent from one end to the other.
Thanks for the link Dan. So any of those things could be causing this vibration. Either way its something I have to have looked at.
I wonder if the road surface has anything to do with what I'm feeling. The problem is always more noticeable on a certain strech of road that I use daily which I'm always braking to a stop from 100km. Rarely do I feel the same problem on other roads, although it does happen. Could the road be responsible in any way for causing brake vibration?
Photography Nerd
Originally posted by dcrc
Does anyone know if Ceremic pads are available . I've heard that they are more expensive, but offer exellent fade resistance.
Audi Driving Snob
Originally posted by ClutchPerformer
Get better TIRES.
Get better TIRES.
Mr. Martin ..
They are actually making Ceramic pads. no break dust, virtually little to no fade. Normally cost about double of a premium metallic pad from what I've learen
Found this by doing a search for Ceramic brake pads.
http://www.tirerack.com/brakes/tech/...rake_pads.html
Photography Nerd
Mr. Martin ..
Mr. Martin ..
Come on Dudes!...You guys are driving brandy new cars and are already talking about changing brakes due to warping,grinding etc. I was so close to trading in my RSX type S for a TSX but I'm so glad that I found this site. As much as I love Acuras I just have to wait till they get some better press on this page. All the car magazines rave about this car but in the end it's the owners who drive it day in and day out who know the true story on a cars quality. In a way I'm sorry I found this site too because I was so set on owning one of those beauty's.
Photography Nerd
People here overreact a lot when it comes to issues with their cars. You'll find that this is an enthusiast site so people are more picky than most.
Bye TSX, hello domestic?
I spend 2 much time here
buy a KIA and supercharge that muthfu$$A!!!!!!!!!!!!
People like to vent on sites like these. Just how many percent of all the TSX owners bother to post here? The complaints you hear does not necessarily reflect the overall quality of the TSX. You can expect first year models to have few problems that are eventually corrected.
Happy owners have better sense than to spend time whining about their car; they get out and drive!![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Afterall, you have warranty to take care of any problem that may arise.
just to take counterpoint here.
my car is 10 months old, i have 21K miles, no problems with brakes. no warping, no vibration. some of us are perfectly happy with our brakes.
I thought the brakes were a little weak and put in EBC
pads from Tire Rack.
Brakes are more than excellent now.
I don't want brakes to last 100k, I want best stopping.
I don't care if I only get 40k out of them. Acura has to
put in long life pads in mass market vehicle.
I would never buy a lifetime pad for example, of course
I want stopping which is opposite properties of long life.
I have no vibrations.
I had another car with warped rotors right away but
Nissan said out of 90 day warranty. I had them turned
for $12 then no problems now for 65k miles.
It's really a common problem. It's new metal and can change
with heat and stress cycles. It will happen with some
statistical frequency that you will get one that changes. After turned they are permanently good. It's not a big deal.
jgs
Brakes
I know I'm late responding to this complaint, but I'm taking my TSX to my Acura dealer for the third time in 14K miles to have the brakes inspected. They squeak when coming to a stop from a slow speed. The rotors have already been resurfaced TWICE in the last 5 months!! I don't drive the car hard - however, I do live in the hills in South. Cal. so I'm sure that's contributed to some of the wear on the brakes. Even so, this doesn't sound normal to have so many problems with the brakes in such a short period of time.
Other than this issue, my TSX has been an absolute pleasure to own and drive.
Re: Brakes
Re: brakes
What I notice is that if I hit the brakes hard-ish at a speed above 35 mph and I go over a bumpy patch on the road while I'm braking, my brakes start vibrating loudly. I figure this is the anti-lock system adjusting, but next time I take in the car to the dealership for an oil change I'll mention this to them. Don't know if others have the same thing.
Registered AssHat
Re: Re: brakes
Hi guys - I'm totally new to all this, but I had the same problem with brakes. I especially notice the heavy vibration slowing down over bumps or with braking in snowy weather. About once a month, I get a heavy clunk when I put on the brakes, as if I hit something in the road. I brought it in, and they said it was the ABS, and that they were fine. They don't feel like any other ABS brakes I've driven, including their loaner car. Since I had more important issues regarding my driver's seat shifting and the casing breaking apart, I haven't followed up on it. Should I let it go? It sounds like an inherent thing going on with TSX brakes. The Service guys can't stand seeing the sight of my Milano Red TSX coming into the lot!
I'd hate to give wrong advice to you Katya, but so many people have called your clunking noises (and mine) the ABS system, I'm inclined to believe it, even though the same thing might not happen with other cars' ABS systems. Just my two cents'.
Klunk I don't recall, I get the ABS vibration occasionally,
like going over bumb while breaking. The low ridges when
going from a road to a drive way will set it off because
I have brakes on and am turning. Occasionally I have
caught a sight of the VSA light flashing at these times.
If you have a place this always happens, try turning of VSA
and see if it doesn't happen.
The Klunk I don't know. I had noise from my brakes at a certain
cold temperature. In the afternoon of some cold days the
noise might not occur and then again at night and morning
temps. I'm not concerned about that.
Since it has warmed up here it hasn't happened in weeks.
I had this happen for the first time going over a bump in a parking lot as I was slowing down for it. Definately felt like ABS to me, only did it for half a second.
Ayumi Hamasaki
Heh, I live in Anchorage, AK so I know how the ABS feels and the VSA. The VSA kicks in a lot, and it helps too. The ABS really hasn't kicked in to much because of the cars braking power and I dun stop at the last minute. The ABS is a grinding sound and I hate it. I hate ABS on all cars and I prefer to pump the brakes instead of hearing that grinding sound that doesn't even help, you usually just keep on sliding.
I just bought my TSX used with 8200 miles on it and It has 10,000 miles on it now. The brakes squeak a little bit, but other than that, there great. Gotta love the rotors all around, no drums =). I'll get the squaking and alignment checked when I go in for my first oil change in April.
And about the post earlier, the one where your glad that you waited to not trade in your RSX for a TSX. Man this car rocks, it doesn't even feel like a 4 banger. It's smooth, quit, luxury, and sporty. It's an awesome car and I would take it over an IS300, Mercedez C230 sedan, or the WRX anyday. Only other car that would change my mind would be the Audi A4. Depends on your taste, some prefer the powerful WRX, but I prefer the luxury, especially after driving my dads 2001 Mercedez S500 last summer
l8ers
Wess
l8ers
Wess
brakes
Everything about this car is awsome except for the brakes. After reading this forum i am wanting to change to some aftermarket parts but at the same time I feel that if I paid $26,000 for a new car they should fix it. I had to have the rotors machined at 4000 miles and now at 8500 miles they are screwed up again. What to do what to do.
Hey Guys,
I just took my 2004 back for 24 K service and I had brake vibration at around 70 k/h. By the end of the service the Service Rep. told me there is a Bulletin out for brake pads replacement and servicing all rotors. It is not recall but if you don't complaint and they will not replace the pads for you.
Originally Posted by vitus
Hey Guys,
by any chance did the dealer give you a TSB number associated with the Bulletin?
Hey jmathew34,
No they did not give me the TSB number. This is on my invoice " 410820 Resurfaced both front brake rotors and updated pads. 1 , 45022-SEA-J11 set pad front "
"411842 Rear brake rotors- Resurface both " . " Replaced front brake pads as per Bulletin ."
One thing to keep in mind guys. Especially after the stealer has rotated the tores or something like that. Most dealers that ih ave ever been to will tighten the lug nuts back on with their "air wrench" in the shop. Those things have NO limitations on torque. Those things will overtorque your lugs like crazy. I believe you're supposed to only torque your lugs to just over 80 lbs. You are supposed to use a torque wrench to tighten the lugs. The more reputable shops will do that. You can use an air wrench to loosen all the lugs you want to. But NEVER take an air wrench to tighten a lugnight. The overtightening WILL cause rotor warping no matter what type of rotors you have.
If the dealer refuses to use a torque wrench. Go home and retorque the lugs with a torque wrench when they are done with it.
Brake vibration
So I had some brake vibration at 4000 and the dealer resurfaced all 4 rotors and 4000 miles later it came back. Turns out it was just the rears which the dealers replaced. So if you have brake vibration try driving and pulling the emergency brake and if you feel a vibration, take it in for some new rotors. Hope this helps
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
