Brake Fluid Flush
Old Jun 2, 2009 | 01:10 PM
randysezz's Avatar
4th Gear
Brake Fluid Flush
Might seem like a dumb question:
How much fluid do I need to correctly do brake fluid flush?
Any brand recommendations?
Thanks!
Old Jun 2, 2009 | 02:44 PM
narutobear's Avatar
Dealer told me 1 but I bought 2 just in case. Just get same from acura.. unless you're going up to dot 4 or 5, then you need to completely flush out.
Old Jun 3, 2009 | 04:42 PM
npolite's Avatar
I would just go get the big bottle of Valvoline synthetic from your local auto parts store. It is about $6 and will cover you in case you want to flush some of the lines a bit more. I've done this several times since the Honda fluid was running a bit too much.
Old Jul 18, 2011 | 10:33 AM
deepen03's Avatar
Proud Acura Owner
ok so I have 94,000 miles, I have good drilled/slotted rotors and just got new pads installed two days ago.. I have never done a brake fluid flush/bleed the lines. I am going to get it done today or tomorrow. How many pints do I need? And should I go with Honda fluid or can I let the guys at the local shop just use their aftermarket fluid? They charge 70 bucks at the place I will go to, including bleeding of all four calipers.
Old Jul 19, 2011 | 10:39 AM
deepen03's Avatar
Proud Acura Owner
alright, so I got it done at the local shop, Thrust Performance nearby. They flushed the reservoir, then filled the new fluid, while bleeding the calipers one by one. And using BG Dot 4 fluid. I asked one of the guys, a TSX owner, who uses the same stuff in his. I can feel a difference in brake responsiveness already.. it was well worth it. and only cost me $75.. not bad.
SidhuSaaB
May 30, 2020 12:40 AM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
