Brake Fluid bleed question
Old Aug 31, 2012 | 10:05 PM
Braz60's Avatar
New owner of a 2006 TSX has 43K miles on it I want to change the brake fluid have read other posts but I have one question can I jack up one side at a time remove the tire and bleed? Or do I have to put the entire car on jack stands remove all wheels so the car is level when bleeding?
Thanks for your input!
Old Sep 2, 2012 | 02:39 PM
Braz60's Avatar
Hasn't anyone blede their brakes
Hasn't anybody bled their brakes to fill with new fluid? How did you guys do it?
Old Sep 2, 2012 | 11:43 PM
PACman's Avatar
I've only placed my car on 4 jack stands when doing this job. Start from the front drivers, go clockwise, end at the rear drivers. Unsure if using 1 jack at a time is harmful.
Old Sep 3, 2012 | 08:44 AM
TexasHonda's Avatar
Not necessary to place on jack stands, but necessary to support car safely on a jack stand w/ jack as backup as you will need to get directly under the car to perform the bleeding.
System flows under brake pedal pressure and does not depend on gravity unless you try a "gravity bleed". Even here the wheel is still much lower than the brake reservoir so leveling is not necessary.
I just ordered a hand vacuum pump to perform vacuum bleeded from wheel. I've always used brake pedal pumping and it's messy.
good luck
Old Sep 4, 2012 | 08:00 AM
Braz60's Avatar
Where did you get the hand pump from? How much was it? I would prefer using this method instead of depending on another person to pump the brakes
Old Sep 5, 2012 | 05:47 AM
TexasHonda's Avatar
Harbor Freight has them on sale for $20+shipping/tax for about $30 total.
good luck
mada51589
Jan 9, 2025 04:40 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
ulrblitzer
Sep 24, 2015 07:42 PM
cacheflowe
Sep 14, 2015 10:35 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
