Brake Caliper Torqu Spec
I am about to change the pads and rotors and i need to know the torque specs for the brake callipers. Since the brakes are kind of important i want to make sure i have them torque to the right specs. Also, you know any tricks or problems i might face please let me know.
Thanks,
Thanks,
Thanks,
Thanks,
These are strictly for the bolt(s) removed to rotate caliper (front) or remove caliper (rear) to replace pads and compress piston.
Front bolts, 36 lbf-lb/5.0 kgf-m/49 N-m
Rear bolts, 27 lbf-ft/3.8 kgf-m/37 N-m
Make sure and have the disc brake piston tool for the rear brakes...it makes it much easier!
nuldabz
Sep 3, 2015 05:49 PM
