Bluetooth code??
Old 12-19-2010, 11:13 PM
4th Gear
jokomosa87's Avatar
Bluetooth code??
I just got a used 08 tsx black/black yesterday. I was trying to use the bluetooth for my cell and it is locked. It says I need to enter a code? Do I have to go to the dealer to get this code or is there number I can just call to get it. My friend's accord audio locked up and all he had to do was call honda and ask for the pass code. Can I do the same?? Thanks.
Old 12-20-2010, 08:45 AM
mrgold35
mrgold35's Avatar
Received 1,545 Likes on 1,201 Posts
The only code my 06 TSX asked for is the 4-digit code to link the phone to the car during phone set-up:
http://www.handsfreelink.com/?page=findaphone
The above link has the instructions for pairing your phone to your car. You might also make sure all old phones are deleted from your TSX. I've had problems with my 06 pairing Blackberry and iPhones at the same time and dropping one or the other phone after a few days.
Old 12-24-2010, 05:57 PM
4th Gear
jokomosa87's Avatar
will try it. thanks!
Old 12-24-2010, 09:43 PM
eg5
user title goes here
eg5's Avatar
only the previous owner knows the pass code. as far as registering this with acura, i dont know if its possible. the solution, take it to the dealership and have them clear all stored phone numbers and pass code entries. (this can only be done using the hds)-passcode.
Old 12-25-2010, 01:15 AM
Jaan Lewaa's Avatar
bluetooth code is the one u select n put same on veihcle n ur phone to attach, same like u r connecting with other phone via bluetooth
Old 12-27-2010, 12:00 AM
eg5
eg5's Avatar
if the system asks for a pass code on your phone, that means one already exists. if you do not know the pass code then one from previous owner is still stored. solution clear pass code with hds.
Old 01-05-2011, 03:45 AM
4th Gear
jokomosa87's Avatar
k. thanks. i'm taking to dealer this week.
Jamus22
06-11-2023 10:08 AM
MetalGearTypeS
08-29-2016 08:28 PM
SUPRMN84
10-07-2015 09:46 PM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: Bluetooth code??
