Bluetooth call doesn't pick-up instantly
Whenever someone call me on the phone, the HFL would ring, I would press the "pick-up" button, HFL then switch back to the radio/CD for 3 seconds (because I'm always listening to music), then switch back to HFL speaker, then I can talk. It is rare that when someone call me and I press the pick-up button, it would instantly take me to the speaker. Is someone else having this problem or is this a normal thing in HFL?
yes i have the samsung u600. everything works flawlessly except the delay when picking up. and also, sometimes the HFL pickups the call instantly so I know it might not be compatability issue
hmm wait, i dont see u600 on the site.....i saw the u620 on the site and i thought that was it. but it still works with all the features....
Make a hole, coming thru!
Sounds like it's "some features supported." My phone exhibits what you're describing when I initiate with the phone, they try the "transfer" feature. It takes two "connections" for the HFL to kick in.
When you're not using the phone, try the command, "Phone, Setup, Status." See if your phone is "connected." Probably will be, but I thought I'd mention it. You mght also try the self-test -- hold the HFL hangup button down for 10 seconds.
MilanoRedDashR
38
09-28-2019 09:13 AM
ivegotthenav
09-11-2015 07:51 PM
IndycarFaster
09-11-2015 02:52 PM
SUPRMN84
09-02-2015 11:50 PM
