Blocked AC condenser drain
Old Jul 11, 2005 | 12:32 PM
owkone's Avatar
How to clean the condenser drain? Where is it located?
I think it is blicked I saw afew drops of water on the passenger side floor mat.
Old Jul 11, 2005 | 12:33 PM
TSX.Fury's Avatar
send me a link to JDM??
Who has a helms?
Old Jul 11, 2005 | 01:42 PM
xizor's Avatar
Bye TSX, hello domestic?
search, you'll find others had this same problem w/ getting water in the floor.
Old Jul 11, 2005 | 05:01 PM
owkone's Avatar
Searched - no joy - if anyone knows please post.
Old Jul 11, 2005 | 05:26 PM
owkone's Avatar
Pardon my bad - the condenser is up front under the hoos - I am not sure what this part is called - but it is drain for the (heat exchanger?) where the water accumulates and can dribble inside in the passenger foot well when the drain is clogged. I need to know how to open that drain.
Old Jul 11, 2005 | 07:50 PM
goddsmack's Avatar
I haven't check the TSX, but can you lift your car from the passenger side near the front tire, look underneath and check to see if you can see a clear plastic tube. Generally that's your drain tube in most vehicles. That's what I would clean first, Toyota's generally have this and my old '95 Accord had this too.
[EDIT] it's isn't supposed to be an "open the drain" type service thing, it's supposed to automatically drip out.
Old Jul 11, 2005 | 08:49 PM
beach accord's Avatar
the correct term is the evaporator drain.
put the car on a lift and blow some compressed air into the drain pipe if you think its blocked.
Old Jul 11, 2005 | 09:34 PM
JeffTSX's Avatar
Subie Tech
I'm not too sure with the TSX but at work we get a lotta them stuck and the rubber tubing for drainning water is located passanger side (well that's where the evap is) under the car and if you look right above lower control arm, you should see it. And beach accord is right, just blow it with compressed air and you'll be fine.
Old Jul 11, 2020 | 07:43 AM
zoopzop's Avatar
Did you get this figured out? My drain line is clogged some where and I am having zero luck with shops or finding out where to blow out. I get water outside of the car and inside of the car. It was suggested I take out the center console to look and see what's back there but I don't wanna start ripping shit out until I know that'll help.
MetalGearTypeS
Aug 29, 2016 08:28 PM
07Acuradude
Sep 29, 2015 03:01 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
