Battery CCA??
Battery CCA??
I have an 04 tsx and been having some problems with the eletric. While I am driving from time to time, the power in the car will turn off and turn right back on again (Dashboard and cd player) The battery I have in there has a CCA of 475?
Any clue if that could be the problem or anyone have any other suggestions??
Also at one point it turned my check engine light on for a day with the code PO685, ANY help would be much apprciated!!
in the 24th and a half...
Well, P0685 is "Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Control Circuit Malfunction". The extent of troubleshooting that code is updating the software on the ECM/PCM...if that doesn't fix it, replace it...if that fixes it, it was a bad ECM/PCM.
It could be a bad ground...but with the ECM/PCM involved, I suspect it's more than that.
Battery CCA only has to do with starting, nothing to do with when running.
dannywb88 (07-24-2012)
MetalGearTypeS
08-29-2016 08:28 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
