ARRRG..Help with Center Console Vents
Old Oct 24, 2006 | 04:01 PM
phillyaj's Avatar
5th Gear
Unhappy ARRRG..Help with Center Console Vents
Hi all,
First off let me say Great Forum!!!. I'm a recent owner of a 2004 TSX (non-Nav). I totally LOVE the car...and coming from a 98 Oldsmobile with 183k miles, its a HUGE change. Anyway, I have an issue with the right vent on the Center Console. One of the plastic piece that holds all the vent-slats together is missing. I did some research and for $30, found an OEM replacement. The new part is the entire center console vent assembly (Left and Right vents). Seeing no easy way to get to the entire vent, I disammbled the OEM vent to get the plastic 'bar' I needed. I was making some headway when the little bar fell down the vent.. I heard it fall, but have no clue how to get to it.
I have two questions?
1) Is there an easy way to get to the venting to retrieve the plastic bar?
or,
2) Is there some 'magic' to getting to the entire vent assembly? If that's the case, i'll order another assembly or go to the junk yard and see if I can find the piece and reassmble it.
I appreciate any and all suggestions....
Old Oct 24, 2006 | 04:23 PM
PACman's Avatar
Wow..that's a tough one. You could try a vacuum cleaner hose and place it down the vent to suck it out. Considering the hose is small enough to get down there.
Old Oct 24, 2006 | 04:27 PM
phillyaj's Avatar
5th Gear
Great suggestion...I have a small shop-vac and I'll give that a shot.
Andy
mlody
Dec 4, 2019 02:11 PM
vpasla1
Sep 17, 2016 07:24 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
