anyone have leaky coolant reservour at the top?
Old Aug 5, 2007 | 07:49 PM
super4's Avatar
since the fist week the car was new the coolant reservour in the nfreont of the engine bay has been leaking a bit from the top. looks like its comming from right under the cap, and it closed tight. is it just me or anyone else have this. any fix out there?
Old Aug 6, 2007 | 02:48 AM
SoCaliTrojan's Avatar
Let me help you!
probably a broken cap...if it's been doing it since the first week, you should have had the dealer fix it
Old Aug 6, 2007 | 05:00 AM
lvcurvs's Avatar
i had the exact same problem. At first i thought it was a split hose or the cap but once i pulled a little coolant out of the overflow tank, still near the full mark though, it stopped doing it.
Old Aug 6, 2007 | 09:49 AM
poltergeist's Avatar
In order to work, the overflow tank has to be vented. The cap is not designed to tightly seal. As mentioned above, you're probably seeing coolant slosh in the tank coming up around the cap. Dropping the level a bit should help.
Old Aug 6, 2007 | 11:18 AM
jlukja's Avatar
Yup, the overflow reservoir shouldn't be filled to the top anyway.
Old Aug 6, 2007 | 12:53 PM
super4's Avatar
thanx!
Old Aug 6, 2007 | 04:11 PM
visuelz's Avatar
East Coast Crew
And if there was a leak, your coolant would be boiling.
IBankMouse
Jun 13, 2020 12:53 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
