Alignment Specs
Old Dec 6, 2004 | 04:05 AM
OldManTSX's Avatar
Alignment Specs
When I tried to get my car aligned yesterday at NTB, they said they couldn't because the TSX was not on their system. Are these the information they need?
Front Caster (spec range 2.47 to 3.97)
Front Camber (spec range -0.75 to 0.75)
Front Toe (spec range -1.00mm to 1.00mm)
Rear Camber (spec range -1.5 to -0.5)
Rear Toe (spec range 0.00mm to 2.00mm)
Rear Thrust Angle (?????????????)
I lifted these info from another post on our site. Would I be able to go back there and hand this to them and they should be able to do it? By the way, anyone knows what the specs are for the Rear Thrust Angle?
Old Dec 6, 2004 | 08:39 AM
sauceman's Avatar
Moderator Alumnus
Your specs look about right. They are in the driver's manual also.
Moving to Problems & Fixes.
Old Dec 6, 2004 | 10:52 AM
OldManTSX's Avatar
I called the Acura Dealership and the person who I spoke with said that the car, being lowered, would not be within spec, and that the best they can do is get it as close to "0". Is this true?
Old Dec 6, 2004 | 11:11 AM
sauceman's Avatar
Moderator Alumnus
Probably, because lowering will alter camber, for example, and to be able to get back to specs, you'd need a camber kit.
Other values like caster and toe however, shouldn't change.
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jsonkimz
Mar 28, 2016 07:49 PM
Tribalheads
Sep 29, 2015 03:24 PM
4drviper
Sep 23, 2015 07:42 PM
