Acceleration Problem
Hi All -
I have a 2004, with 108,500, 6 speed. Within the last two months, an annoying and hard to diagnose problem has developed. Whenever I try to accelerate (going normal speeds, not racing or hard launch from a stop), the car feels as if it is hesitating, but in a sporadic fashion. For those of you old enough, it's as if this car had points, and they need to be gapped!
Under a higher rev (i.e. >3000 RPM) launch from a start, or downshifting (so the revs go higher), this "hesitating" is not apparent.
To date, I've run a couple of bottles of Chevron Techron, and changed the VERY expensive air/fuel ratio sensor (the one in the cat). None of this has been effective
Has anyone experienced this problem?
could be the APP (Accelerator Pedal Position) sensor starting to fail - does your car hesitate while cruising at lower-ish RPMS?
My 04 hesitates while cruising at constant speeds .. only during lower-RPMs and it's not everyday.. from everything i've read and tried out.. i've narrowed it down to the APP Sensor.. there's another thread on here too from a few days back that details a similar problem to yours and mine...
There are more documented cases in the TL forums that i've read as well
Here's the thread from a few weeks back
https://acurazine.com/forums/1g-tsx-problems-fixes-128/success-app-sensor-replacement-cured-p2138-non-smooth-accelerator-response-819824/
The symptom does occur at the lower RPM's and is daily, repeatable and annoying. But, there was no code! I wonder why. I'll have to check the APP sensor. Thanks for the help and the link to the other thread. I'm going to read it now.
One more thing, when I'm on cruise control, there is no "hesitation". Like the one post said (the other thread), does the cruise control bypass the APP sensor?
Here's another thread from the TL forum that sort of describes your problem exactly, I'm thinking more and more it's the APP sensor
https://acurazine.com/forums/3g-tl-problems-fixes-114/replaced-app-sensor-today-817806/
Good luck! and let me know what you find out, as i'm curious myself! though i'm 99% sure it's the APP sensor causing my problem.
Cool! Thanks for the head's up. Unfortunately, I'm on business travel for a month, and I won't be able to get to the car during that time.
But I'm REALLY curious about the APP.
Not that this is a good play on words, but I didn't know that my TSX has an APP (like my Android phone)!
But I'm REALLY curious about the APP.Not that this is a good play on words, but I didn't know that my TSX has an APP (like my Android phone)!
Got the APP installed (my brother-in-law owns a shop). He told me that the "hesitation" is gone, but he's going to go on a longer road test. Looks like your solution was 100% money!
Can't wait to get home and drive it!
Thanks!!
Thanks!!
Hi to all. I couldn't find the introduction thread, so I thought I'd jump straight in here.
My question is about acceleration and this thread seemed to fit my needs.
I'm in Australia and I just bought an '05 Accord Euro 6M with 56,000 miles. I find the acceleration to be difficult from a standing start without sipping the clutch. The car starts to take off and then seems to drops revs and then keeps going again. It's also very difficult to drive the car at low speed - it just seems to lurch around
I'm trying to figure out whether it's just my driving or if it might be the APP sensor.
Do my symptoms fit with other diagnosed APP sensor problems.
I'm keen to ask here before I try to buy one, because the APP sensor part in Australia is $300.
cheers to all
cheers to all
Hi,
Actually, there is a link in an earlier post in this thread.
Your symptoms seem almost identical to those that were plaguing me. The change of APP sensor (according to my brother-in-law) has cleared the most of this problem. I was told that if abruptly hit the accelerator (while in 1st), that the transition was not very smooth. He described this solution as 90%.
Given that, there may be something else with my car, and I have over 108,000 miles.
The price you paid, given is on the expensive side. I paid $184AU.
Cheers, gkkitag
In first gear at sort of walking speeds or a bit faster my car just bounces along. I have to put in the clutch to stop it. It's kind of embarrassing in parking lots. I must look like a learner
We get screwed on parts regularly. eg. I bought new wiper blade inserts the other day for $15 each ($30 the set). The same blades would cost you less than $11.
There are some great benefits to living in Aus, but cheap car parts aint one of those benefits.
I'm doing up an order for oemacuraparts.com who seem happy to send parts across the water.
G'Day OZ_Rob -
Sorry to hear about the prices. Wow! I haven't been in Australia in six years (was in NSW, staying in New Castle). Had a good time. Glad to hear you have a parts supplier.
I've got one more part, then I'm done (until the next time). I want to get the folding side mirrors.
cheers to all
cheers to all
The problem I've quoted though...sounds more like the checkvalve in the clutch. Making it so that you have to baby the clutch in 1st and 2nd so it's not super jerky. I've been driving manual hondas for a long time and before removing the checkvalve...I seriously wondered why I was having such a hard time.
Check this thread:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/113-removal-slave-cylinder-check-valve-734300/
G'Day OZ_Rob -
Yeah, parts availability is good but the prices are high, but through the power of the internetz, we can fix that ...snip...
Check this thread:
https://acurazine.com/forums/showthread.php?t=734300
Check this thread:
The first problem could be the check valve, but the second one has the clutch already engaged. The alternative is that with the high compression it doesn't like driving really slowly.
Has anyone else got a manual they can comment on slow speed (walking pace or a bit faster) driving?
I've autocrossed my car a couple of times, and don't remember this happening. Possibly because I launched at slightly higher than normal RPMs. Normally, I drive like the old man that I am, use the cruise control, no jack rabbit starts, etc. No problems.
I've been driving manual for a long time and the TL made me feel like it was my first week again...jerky as heck if you didn't pay really close attention to the gas you were giving in relation to clutch release. Took checkvalve out and BAM...car drove the way I expected. IMO, it's a must for all 6MT.
Hi,
You can order the part online for $140shipped from here:
http://www.acuraoemparts.com/delray/...AL_SENSOR_ASSY.
I'll have to check this out. There are a lot of places on "the mainland" that will not ship to Hawaii (for a variety of reasons - some not even USPS). Hopefully, this site is not one of the "Sorry, but we don't ship to Hawaii or Alaska" places.
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Mike Bertram
Sep 10, 2015 09:27 AM
2004, 2008, acceleration, accelerator, acura, adjustment, app, cls, mdx, problems, replace, sensor, slow, tl, tsx
