ABS, VSA, VSA-OFF lights all turned on and stayed on...
Old 09-18-2003, 07:44 AM
Yui
Yui's Avatar
as I was driving to work this morning... I'd washed the car last night but then I'd taken it out for an errand, and hadn't seen the lights on then... but they turned on this morning, and after I parked, I restarted the engine but the lights stayed on... There was no noticeable degradation in performance in either acceleration or braking, and I know what VSA feels like and it didn't feel like that was on either, so I'm quite confused.
I called Acura and it looks like I'll have to take it in and they'll give me a loaner car or something? Damn, that's such a hassle... Anyone have any experience with this? Maybe one of the dealers have run into this problem before...
Old 09-18-2003, 09:27 AM
moda_way's Avatar
Somebody did have the VSA light on constantly. I believe it was a faulty plug on one of the hubs of the wheels.
I learned that if the wheels aren't under load (like up on jack stands) that you can't rev the engine.
Did you by chance use a lot of cleaner or a high-pressure hose on the wheels? If you somehow got water in the wheel sensors, that could easily explain this issue.
Old 09-18-2003, 09:42 AM
Yui
Yui's Avatar
I didn't even clean the wheels cause it was just a quick rinse... but all three lights are on, and I do suspect something to do with the sensors...
Old 09-18-2003, 08:58 PM
Yui
Yui's Avatar
After checking the manual, apparently there is something wrong now with my VSA and my ABS... whee time to see the dealer.
Old 09-19-2003, 05:46 AM
moda_way's Avatar
Keep us posted on the fix!!!
Old 09-19-2003, 07:10 AM
gogozy's Avatar
yes, check with dealer, could be something stuck or block the abs/vsa sensor on the wheel!!!
Old 09-21-2003, 08:07 PM
Yui
Yui's Avatar
... It turned off by itself this afternoon, then turned on again later, then turned off tonight as I was pulling in. Still haven't had time to go to the dealer, probably won't get to till like, next Monday...
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
PortlandRL
09-14-2015 12:01 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: ABS, VSA, VSA-OFF lights all turned on and stayed on...
