Abs vsa and triangle lights on
Old Jan 17, 2016 | 05:41 PM
Miguelon's Avatar
Exclamation Abs vsa and triangle lights on
Hi guys I'm New To The Site I Have A 04 Tsx And I HAve The Abs Vsa And The Triangle Lights On They Told Me I Had A Bad Speed Sensor Wich I Replaced With New One That's When All The Lights Came On Went To The Dealer To Get IT Scanned And It Has No Codes They Told Me It Could Be A Bad ABS pump Got A New One Got It Installed Turned The CAr On All The Lights Went Off Bled All The Brakes Propperly When Started To Drive The Car Once I brake The Pedal Shook Did It 3 Times And All The Lights CAme Back On Any Advice On What Could B Wrong Or Something Else I need To Check In Order For The Lights To Go Off And Work Properly I Will Appreciate Any Help If Someone Experienced This Issue I'm having THANK U...
Old Jan 18, 2016 | 03:31 PM
burijon's Avatar
Sounds like that ABS pump isn't installed right.
I'm assuming you did get the codes read? Most car parts stores will read them for free in the hopes of selling you a part. Let us know the exact codes.
The fix for my VSA light was the VTEC Solenoid. It's right behind the head on the passenger side.
Old Jan 19, 2016 | 02:34 PM
curls's Avatar
Someone stole "My Garage"
Save yourself a lot of trouble and look for BRAKE LIGHTS when you press the brake pedal.
If you have no brake lights, I'll bet dollars to donuts that your brake switch has failed and is causing ALL of those indicator/warning lights on your dash.
The part is under $20 and takes only a few minutes to replace (it's under the dash where your brake pedal is).
