6mt - First gear selection issue
I was wondering if anyone has had this problem.
It is a situation when you are stationery and the gearbox will not select first gear (and first gear only) unless you:
It seems to be an intermittent problem I have had with the car since new (now at 30,500kms). The Honda dealer says the first gear selection is normal. They have bled the clutch - that didn't do anything. They also replaced the gear box oil - still the same.
Is this normal and should I push Honda to fix it.
- clutch in and out
- select another gear then 1st
- or give the engine some revs and then it manages to slot into first
Normally, when ur rollin' even at a fair low speed you might not be able to go into first, but since you said you were stationary, i don't know what the problem might be.But if you were stationary, you wouldn't need to rev the engine to get it into first gear though
Hi yfin! It's me, aaronng. Hehe. Just to add to the forum members, my car would not engage first at low speeds for the first 2 months. After that, I had a master cylinder replacement and I am now able to enter 1st gear even when I am above ~20mph. You reckon they brokemy 1st gear lockout?
Any one else find this?
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
justin7779
Dec 25, 2015 10:33 PM
mugen_kid
Nov 13, 2015 10:38 PM
Mike Bertram
Sep 10, 2015 09:27 AM
