6mt - First gear selection issue
I was wondering if anyone has had this problem.
It is a situation when you are stationery and the gearbox will not select first gear (and first gear only) unless you:
It seems to be an intermittent problem I have had with the car since new (now at 30,500kms). The Honda dealer says the first gear selection is normal. They have bled the clutch - that didn't do anything. They also replaced the gear box oil - still the same.
Is this normal and should I push Honda to fix it.
- clutch in and out
- select another gear then 1st
- or give the engine some revs and then it manages to slot into first
Normally, when ur rollin' even at a fair low speed you might not be able to go into first, but since you said you were stationary, i don't know what the problem might be.But if you were stationary, you wouldn't need to rev the engine to get it into first gear though
Driver/Detailer
Hi yfin! It's me, aaronng. Hehe. Just to add to the forum members, my car would not engage first at low speeds for the first 2 months. After that, I had a master cylinder replacement and I am now able to enter 1st gear even when I am above ~20mph. You reckon they brokemy 1st gear lockout?
Any one else find this?
Originally Posted by iamhomin
It goes only half way to first before you try the a, b, and c method right?
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
justin7779
12-25-2015 10:33 PM
mugen_kid
11-13-2015 10:38 PM
Mike Bertram
09-10-2015 09:27 AM
