2007 tl wont start again
my 2007 tl wont start again i hade the fuel pump replaced and still have this problem turn the key and the starter just keeps turning over no fuel is getting to the engine i think cause i put some gas in the in thru where the air filter hooks up and it started up and cut off but i had this promblem yesterday too and it started back up 15 mins later and drove fine until tonight it started up and bogged down and died and then no start and it did that before and they replaced the fuel pump maybe i got a bad fuel pump i dont know any ideals
Do you hear the fuel pump coming on for a few seconds when you turn the key to ON position without starting the car? It would be better to post this in the 3G TL section so that others with the same problem or knows more about the car could better assist you.
Either the fuel pump is defective, or it's not getting power. I would suggest you check the main relay, or better yet bring it back to where you got it repaired and tell them to correctly fix it.
Luis J. Rodriguez
09-12-2015 10:00 PM
