2006 TSX Rattle / Buzzing in Driver's Door Window Switch
I have done a search and haven't seen any fixes to this specific problem. In my new '06 TSX (1,500mi) there is a buzzing/rattling comming from the driver side window switch. The exact cause is the plastic insert that goes between the actual switches and the switch housing itself(Hope that made sense) is loose and vibrates loudly from any bass sound from the speaker. Even with the volume around 6 on some music causes this. Anyway, took it in once and the switch was replaced. Still have the same problem, so it looks like a design flaw within the switch. Has anyone noticed this, and have a fix for it? I'm wondering is it really a design flaw or did I just get two bad switches in a row?
I found the instructions on how to remove the switch housing, but it seems pretty difficult to remove it cleanly, I made an attempt and couldn't easily get a screwdriver in anywhere to pry it out. I have an appt to take it back on friday.
Thanks!
Thanks!
k6biv
09-10-2015 06:37 PM
ahsm
09-09-2015 08:35 AM
