2005 TSX cold rough idle :(
Old Mar 10, 2013 | 04:02 PM
Danny Fung's Avatar
6th Gear
Hi all Acurazine forum buddies!
I have had this problem for quite some time. The car will start up fine in the morning (sometimes it will crank longer and struggle to start). After startup, of course, the RPM goes up to 1200 range. In Canada, winter is brutal. I guess this is normal because it needs to warm up. However, when it is in gear (R or D), especially when I press the brake pedal, you can feel that it idles rough. You can literally feel the car shaking. You can feel the vibration through the drive wheel. But all this will go away after about 5 mins of driving and when the engine warms up.
My question is should I be concerned? Is this normal? I just bought the car half a year ago and it passed the 200 point inspection with all greens. I am a rookie when it comes to car. Any input will be greatly appreiciated. How come the rough idle goes away if this is an issue? Please help and thank you!
Old Mar 11, 2013 | 07:04 PM
Danny Fung's Avatar
6th Gear
any thoughts guys?
Old Mar 12, 2013 | 02:38 PM
Miamicarfan's Avatar
Hello
Several questions:
1) How miles does the car have?
2) What is the outside temperature when car shakes within the first 5 minutes?
Old Mar 30, 2013 | 07:31 PM
Danny Fung's Avatar
6th Gear
It has about 77,000kms and the temperature outside is below 0'C.
Just changed the spark plugs with little improvement to the shaking. But it's still there. I am almost at a point that I think this is "normal".
Originally Posted by Miamicarfan
Hello
Several questions:
IBankMouse
Jun 13, 2020 12:53 PM
agupta3224
May 23, 2017 08:30 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
RobbDizzle
Oct 15, 2015 11:16 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
