2005 tsx clutch burnt
Old Nov 26, 2009 | 11:48 AM
jd33's Avatar
So the clutch on my 05 tsx is gone at 75,000 kms. The dealer says it is not covered by the warranty unless it is a defect so they have to take it apart to determine the cause. But they warned that most likely it is not covered and it's going to be around $1500 (cdn)
Does anyone have any advice for me before my appointment to take it in? Do I have any recourse? I drive the car perfectly... but I did stupidly buy it with 4000 kms on it. I got $3000 off the price for that but I guess I'm going to pay for it now
Many thanks.
Old Nov 26, 2009 | 03:21 PM
Googa's Avatar
a dealer will usually get you on a clutch. it's meant to wear, but shouldn't wear out by 75,000 kms if driven by a driver who knows how to drive. Assuming the clutch was fine when you got the car at 4000 kms, did it steadily wear out, or die all of a sudden recently?
Old Nov 27, 2009 | 11:47 AM
SoCaliTrojan's Avatar
Let me help you!
Warranty is for defects only, not items that wear out. If your clutch broke in half, they'll replace it. If it's worn because of driving habits, then they won't replace it.
Consider using an aftermarket clutch. It should be cheaper than oem, and there are various tiers of clutches (racing clutches, like oem clutches, and in-between).
Old Nov 27, 2009 | 01:00 PM
Itchytoe's Avatar
Modding newbie
In 4,000 km, you would have to seriously abuse the clutch to have any lasting detrimental conditions in it. It's possible, but highly unlikely that those first 4,000 made any difference. Assuming you're right about knowing how to drive a standard tranny, it's a normal wear item and isn't covered by your warrenty unless it is defective in some way. Just wearing out quickly isn't a defect, or a sign of a defect.
I also will suggest that you look at aftermarket clutches. They are both cheaper and normally higher quality than the OEM clutches. They can also give you better performance if you know what you look for.
Old Nov 27, 2009 | 07:49 PM
RogerPodacter's Avatar
So, do you like...stuff?
I've always read that honda clutches are very good for long life and durability. Is it really that much better to go with an aftermarket clutch? What is the price of the stock clutch vs a good aftermarket clutch?
Old Nov 28, 2009 | 02:56 AM
mdkxtreme's Avatar
I wouldn't take it to the dealership because they would get you on the labor afterwards. Try taking it to an independent mechanic and see if they can quote you a lesser price. This is definitely a wear and tear issue so I don't think the dealership will cover it.
I don't mean to assume that you don't know how to drive a manual, but maybe it's your clutching habits? Like revving it above 2k RPM before letting go of the clutch? Riding with the clutch? Even resting your foot on the clutch can wear out the clutch. In highschool I had a stupid friend who revs above 4k rpm before letting go of the clutch. Then he complains why he has to replace the clutch at 30k miles.
Old Nov 28, 2009 | 11:46 AM
What is a good or average price to replace our clutch from an independent mechanic? I just went this week to an independent place and the guy quoted me around 700 dollars. Is that too good to be true? How much do dealerships charge on average?
Old Nov 28, 2009 | 01:01 PM
kanonen's Avatar
TSX 2005 Manual
I once bought a solra with 71k (miles) on it. 20k later the clutch went down. I was smelling burned clutch maybe a week after I bought it and only realized that it was clutch smell when it started skipping a year later.
But yeah you really have to have abused it a lot to damage the clutch at 4k. You are probably a bit aggressive with the clutch ...Maybe driving on snow/ice...but I doubt Vancouver has a lot of it!
Jd33, let us know what you do and also, what were the specific signs of your clutch going down...
Old Nov 28, 2009 | 01:25 PM
kanonen's Avatar
TSX 2005 Manual
I forgot to say that it did cost me $1300 at a toyota certified mechanic to fix the clutch on a 2001 solara. So your $cdn 1500 is normal. I wouldn't give my tsx to a random mechanic for a cheaper price on a clutch though!
Old Nov 30, 2009 | 12:34 PM
jd33's Avatar
Ya, thanks for all the advice. You guys are right about the warranty - only for manufacturers defects. I got a quote from an independent garage and then phoned pretty much every Acura dealership in the area for quotes.
The independent garage quoted $1400. Quotes from Acura dealerships ranged from $1400 - $2000. So I took it to the dealership with the lowest quote - they also had the best customer service.
Maybe I should re-look at my driving style... I don't rev the engine high, but maybe I do rest my foot on the clutch too much. Oh well, I did all I can do, just have to buck up and pay now. Again, thanks for the help.
Old Nov 30, 2009 | 12:36 PM
jd33's Avatar
BTW, it's so expensive because it's listed as 9.1 hrs. - Have to take the apart the transaxle.
Old Nov 30, 2009 | 01:13 PM
mdkxtreme's Avatar
^^Make sure the dealership gives you a loaner then.
Old Dec 1, 2009 | 04:06 PM
HoRRo's Avatar
iVTEC no koe
For a Canadian perspective, in Toronto, most reputable independent shops charge about $450-550 for the labour of replacing a clutch on the TSX.
Old Dec 3, 2009 | 09:32 PM
psteng19's Avatar
Yeah... that'll kill a clutch in no time.
And revving high doesn't wear the clutch if it's fully engaged, which it should be if you're revving that high.
Old Dec 3, 2009 | 11:10 PM
Itchytoe's Avatar
Modding newbie
+1!
Old Dec 4, 2009 | 12:07 AM
PrecyseStylez's Avatar
Special-K
You can find a better deal than $1400! I purchased my Exedy Stage 2 clutch/light weight flywheel combo and installed it all together for alil over $1100.. It was installed over here in NJ at Turbo Trix Racing. $1400 seems alot for a stock clutch and install.
Old Dec 4, 2009 | 10:42 AM
Is the tsx manual tranny any different than other transmissions in terms of replacing the clutch? Just wondering if you were to find a good deal from an independent shop if you need to worry about getting a bad repair or something screwed up from lack of knowledge? Or is a clutch swap pretty standard on any car. One shop here quoted me around 700 bucks for a new clutch and i thought that was too good to be true. But a co-worker recommended this shop he uses them for his acura TL for general auto work. But i don't know if i could trust them with a new clutch.
Old Dec 4, 2009 | 12:38 PM
kanonen's Avatar
TSX 2005 Manual
folks..he is in canada...an oil change costs not less than $50 cdn at a dealer out there...
Old Dec 4, 2009 | 12:39 PM
kanonen's Avatar
TSX 2005 Manual
i'd be glad to have some names...that's like cheaper than in the US!
Old Dec 19, 2009 | 01:56 PM
ennzzo's Avatar
I replaced my clutch with a Exedy Stage 1 with a lightweight flywheel at 95k miles. If I could go back to that moment I would have put an oem back in. I am now at 106k and probably will need to replace it again within 5k....
Old Dec 19, 2009 | 04:59 PM
Why would you go back to the stock clutch? Does it last longer?
Old Dec 20, 2009 | 03:19 PM
PhiDelt's Avatar
When my clutch went on my RSX at 99000 Km's(just b4 warranty was out) i told them it was popping out of gear when driving, and then they never questioned me and i got a whole new tranny (Acura dealership in Winnipeg)
Old Dec 20, 2009 | 08:48 PM
Let me help you!
A clutch that only lasts 11k to 16k...wow
Old Dec 21, 2009 | 01:39 AM
I can't imagine his clutch is going out already, after market or not.
SidhuSaaB
May 30, 2020 12:40 AM
tsx_boy
Dec 13, 2019 08:33 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
