2005 Acura TSX
2005 Acura TSX
Took it to tire shop for a flat repair and car would not start. Battery checked fine no check engine light, got a jump car worked one week now dead again and will not jump start
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
Does the car crank over fine but not start/run or engine does not turn over w/ starter?
If crank/no start suggest attempting to start w/ 10 sec spray of throttle body cleaner into air intake (remove filter to access).
If car briefly starts/runs then fuel pump/fuel deiivery issue. If car does not start then ignition spark is being prevented somehow; fuses, sensor inputs, etc.
good luck
good luck
Teriyakibbs
07-18-2017 10:55 AM
Andrew71066
06-28-2017 12:56 PM
spoka
08-26-2011 12:03 AM
