2005 Acura TSX
Old 11-11-2017, 04:37 AM
Helpingafriend's Avatar
2005 Acura TSX
Took it to tire shop for a flat repair and car would not start. Battery checked fine no check engine light, got a jump car worked one week now dead again and will not jump start
Old 11-11-2017, 07:27 AM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
Old 11-12-2017, 12:36 PM
TexasHonda's Avatar
Does the car crank over fine but not start/run or engine does not turn over w/ starter?
If crank/no start suggest attempting to start w/ 10 sec spray of throttle body cleaner into air intake (remove filter to access).
If car briefly starts/runs then fuel pump/fuel deiivery issue. If car does not start then ignition spark is being prevented somehow; fuses, sensor inputs, etc.
good luck
Ron A
04-01-2024 11:13 AM
csmeance
1/2G MDX (2001-2013)
63
10-06-2018 05:13 PM
Teriyakibbs
07-18-2017 10:55 AM
Andrew71066
06-28-2017 12:56 PM
spoka
08-26-2011 12:03 AM
Quick Reply: 2005 Acura TSX
