2004 TSX inside cleaning...(seat removal, center console removal)??
I need to remove my front seats to clean the carpet.
A hateful cop searched my car a few months back in SC, and poured 20oz or tea into my center console area..........so I want to remove that too.
My ceilings are a bit dirty too...so Im wondering if anyone has advice on that?
Basically I just want the inside of my car to feel clean again. Advice would be greatly appreciated. If there is someone I could take this to get it all done, I would gladly do it.
FSM has caution to disconnect battery and wait 3 mins before removing holddown bolts and disconnecting seat wiring connectors.
A further related caution was to be sure you had the anti-theft code/s before disconnecting battery.
Suggest purchasing a FSM to guide your work. Well worth investment. Removal procedure is 4 pages of instructions and graphics.
good luck
good luck
Removing the front seats are actually pretty basic. If you have any previous history with toying with civics/acuras it's very similar. There is 4 plastic covers which are covering the 12mm bolts and 14mm bolts at each corner of the seat. Once you remove the bolts you will see the exposed wire connectors under the seat which need to be disconnected. Then the seat comes out.
cycdaniel
12-17-2019 10:58 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
