2004 TSX - Drive belt auto-tensioner pointer range markings?
Old Apr 10, 2019 | 03:28 PM
samh's Avatar
Would someone with experience be kind enough to comment on exactly how the proper range is marked?
Have seen various overlapping/contradicting items online that consider either the smaller square the proper range (a comment online), the long rectangle the proper range (less-than-clear owners manual drawing), and both shapes combined the proper range - with the common central border the ideal "center" to point at (a multi-year TSX service manual graphic).
Old Apr 10, 2019 | 09:37 PM
Reorge's Avatar
See attached
Old Apr 11, 2019 | 03:07 PM
samh's Avatar
Well mine certainly looks in range. Guess I'll have to use that wet-it-with-water trick seen here to see if the squeal is from the belt itself.
Thanks for posting that graphic - it confirms what I'd seen in a Service Manual found online. It's more explicit (the inset) and shows a wider range than the Owner's Manual diagram (attached).
Out of curiosity, would anyone know in which direction the pointer would "move" as the belt loosens/gets less tense? (If the owners manual drawing is simply more strict than the service manual, I'd guess towards the right into the square)
Old May 4, 2019 | 09:00 AM
kipsy's Avatar
mine as making noise when cold, local mechanic put some lube on it, not too much, and all is good now.
hitesthonda
Jun 17, 2017 06:28 PM
chris03tl
Jan 11, 2014 02:50 PM
lejunq
1/2G MDX (2001-2013)
Jun 2, 2013 01:55 AM
gsclifton
1G TSX Problems & Fixes
Mar 11, 2011 10:30 AM
23109VC
Aug 31, 2009 05:57 AM
