2004 TSX Acceleration vibration when around 30-40mph
I was hoping someone had a similar situation as mine and found a solution. I知 at 133,000 miles on my 04 AT TSX and lately I feel a slight vibration at around 2,000rpms but if I either let go of the pedal or accelerate even more it値l go away. If I leave the pedal on a steady pressure around 2,000rpm it値l keep vibrating. I can稚 seem to find the issue, I致e even changed my air filter and clean my carburetor and new Ngk sparks and ignition coils on all 4. Hopefully you guys have a possible solution or point me in a direction. Thanks
your issue is believed to be your passenger side axle and the general consensus is to replace it with only oem. Well known problem, i have it too, but i just keep accelerating to get rid of the issue. 😁
mariotsx (03-08-2023)
carburetor? Im guessing you meant throttle body since our cars dont have carbs.
Johnnyt89
1G TSX Problems & Fixes
11-09-2018 03:39 PM
rthammer
4G TL Problems & Fixes
01-12-2014 09:53 AM
